Hello All
Yes, I am still here and have not forgotten all the help, tips and advice I received in resuscitated my 4002. However, as I am a working man as I'm sure most of your are, work remains 'in progress' but the 4002 is almost completely listenable - in fact it now has a semi-permanent place on a coffee table in my lounge and the Garrard 301 which also shares the room, gets much less plays than my 4002.
Work done on it since I last posted, was to replace all the troublesome original switches under the control panel with dinky little micro switches which improved matters a lot.
Last night, I took a lot of time to adjust the platter to be flush and dead centre to the surrounding cover plates.
I just have another question regarding the platter spindle bearing. Everything is spotlessly clean, unscored and the bearing well is filled with some good quality synthetic fishing reel oil.
I have however noticed there is a huge amount of sideplay on the bearing shaft. If one spins the subplatter, it spins freely and without 'wobble'.
Is this shaft sideplay intended and normal? Was it made like this or is it wear?
Regards
dauphine
