Latest post 10-14-2011 6:15 PM by Vienna. 2 replies.
Page 1 of 1 (3 items)
  • 10-14-2011 3:37 PM
    • kimhav
    • Top 500 Contributor
    • Joined on 09-03-2007
    • Sweden
    • Posts 127
    Audio output from BS9000 via BV10 with PL connected speakers
    Hi!
    If a BS9000 is connected via ML to a BV10 which have 4 speakers connected via PL - does the BV10 then need to be turned on when playing music or can I assume that the ML will handle the speakers regardless of the BV10?
  • 10-14-2011 5:02 PM In reply to
    • petermc
    • Joined on 04-16-2007
    • Shepparton, Australia
    • Posts 87
    Re: Audio output from BS9000 via BV10 with PL connected speakers
    The tv will need to be powered on at the wall but does not need to be switched on to use the 9000.
    Most of the commands are via the tv (except for the timer function).
  • 10-14-2011 6:15 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    kimhav:
    NO, but only audio components of your BV-10 will power up and the LCD panel will still be completely off.
