Hi!
If a BS9000 is connected via ML to a BV10 which have 4 speakers connected via PL - does the BV10 then need to be turned on when playing music or can I assume that the ML will handle the speakers regardless of the BV10?
kimhav:can I assume that the ML will handle the speakers regardless of the BV10
NO, but only audio components of your BV-10 will power up and the LCD panel will still be completely off.
