I have had my house cabled in cat7, in my patch cabinet I have a masterlink distribution panel, b&o products connected to the cat7 by the b&o masterlink to cat7 cables and then patched with b&o patch cables in the cabinet to the masterlink distribution panel all work perfectly.
I also have a boelink passive and a beolink active, these are placed in the patch cabinet, these are directly connected to the masterlink distribution panel with b&o ml to cat7 cables, and neither device is working. If I take the masterlink to cat7 cable from either of these devices and plug it into a cat7 socket then pacth that to the masterlink distribution panel it works.
Does anyone know why the first method isnt working or if this methed is supported using a different cable.
Regards
peter
My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
