Latest post 12-20-2011 5:08 AM by kallasr. 9 replies.
Page 1 of 1 (10 items)
  • 10-12-2011 4:43 AM
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    How to update Beovision 3-28 STB-C List?
    After I got a Beovision 3-28 for close to nothing... (everybody seems to want to get rid of the bulky TVs and buy the flat screens) I wanted to set up the STB-C to work with my DBox 2.
    But in the List (STB Table 5.27a according to the service menu) there are only 2 entries!
    Does that mean, the dealer that set up the tv deleted all the other entries???
    If so, how can I update the list myself? I know it is a software update.
    What cable is needed? I suppose I will not need to open the TV, should work via the IR connection...
    And then use a Flash Tool (where to download?) and cables: 3375397 (cablekit)?
    I updated the firmware of lots of Set-Top-Boxes, Routers etc. using ethernet and/or RS232 cables...
    Any help is very much appriciated - PMs are welcome, too Wink
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 10-19-2011 2:28 AM In reply to
    Re: How to update Beovision 3-28 STB-C List?
    Ralf,
    Your Beovision 3-28 has a STB-C and its table of 3rd party STB's is defined by a physical chip installed in the set top box controller.
    So, this is NOT upgradeable by using a flash software tool, you have to replace a physical chip.
    In recent years the PUC was introduced which IS software upgradeable.
    So, when you see B&O documentation which says STB-C you know it uses a hardware chip and when you see PUC you know its software upgradeable.
    Regards Keith....
  • 10-19-2011 3:09 AM In reply to
    • kallasr
    • Posts 1,077
    Keith,
    thanks a lot for your help.
    That is what I thought.
    BUT - can the dealer delete all entries except for two?
    AND: I read that the Beovision 3-28 chassis is similar to Beovision 1/MX 8000 chassis.
    In the BV1_updateIII_863x_service_onsite-eng.pdf doc I find the following:
    So, maybe sw update could work?
    (If cable kit is available and software tool is at hand).
    Thanks again!
    Ralf
  • 10-19-2011 3:28 AM In reply to
    The Beovision 3 STB-C can only be updated with a chip change.
    Why there are only two entries, I cannot really understand why except I noted that you say that it uses table 5.27a except there is no version 5.27a as far as I am aware. The latest table version for Central Europe is version 4.29 and the entries are shown below.
    So, I can only assume, that either the STB-C chip is faulty or someone has programmed their own chip.
    Regards Keith....
  • 10-19-2011 2:45 PM In reply to
    Keith, there are a few CRT's that are upgradeable with the flash tool. The MX8000 is one of those, and so is the 3-28. However, the 3-32 is not.
    Ralph, you cannot do this by your self. Your dealer has the right (hardware) tools to get the job done. Good luck!
  • 10-19-2011 3:11 PM In reply to
    • akoro
    • Top 500 Contributor
    • Joined on 08-07-2008
    • Espoo, Finland
    • Posts 88
    • Gold Member
    BV3-28, MX8000 and BV6-22 are quite similar sw wise and these all can be updated with Service Tool / IR Table Generator. Something your dealer / installer can easily do at home or in shop.
    Avant, BV3-32, old MX and BV5 need to have the chip to be changed. Not that complicated job either.
  • 11-02-2011 3:34 PM In reply to
    Hi!
    We have a new chip and a BV3-32 with stb-c. But where is the chip located. You say it´s not that complicated a job. The bv is dismantled but can´t find the chip
  • 11-02-2011 6:10 PM In reply to
    The chip is located on the stb-controller. To locate the controller, just follow the leads (2 wires) from the female ir-socket.
  • 11-03-2011 5:03 AM In reply to
    • akoro
    • Espoo, Finland
    • Posts 88
    • Gold Member
    hagan:
    Hi!
    I highly recommend to upgrade to gold membership to get access to service manual for the tv.
    The chip is quite well hidden behind the main chassis in a separate stb-controller pcb and yet inside a metal case. After finding the !correct! chip it is not that complicated. And word of warning here - be sure to mount the metal casing top plate in the same orientation as it was. If you wont you will make a short circuit and it could blow the controller!
  • 12-20-2011 5:08 AM In reply to
    • kallasr
    • Posts 1,077
    Just to let you know how I did proceed:
    1. Tried HDR1 (STB-C puilt in) - with Nokia Dbox 2.
    Very slow
    2. Tried HDR2 (STB-C puilt in) - with Nokia Dbox 2.
    Very slow
    So, got rid of the Nodia Dbox 2 and:
    3. Tried a Technisat Digicorder S1 with hardisk built in
    Fast enough - works great!!
    Another (more expensive) solution would have been to have ULF (hardware-)upgrade my Nokia Dbox 2 with his controller.
    Best of both worlds...
    But it is TV #4, not used too often, so I can live with the "not so nice" Menu of the Digicorder.
    Ralf
