Hi folks,
Perhaps someone could help me in one of two ways:
1) Provide contact info for someone to do investigation / repair of B&O in Gloucester / Bristol area or
2) Provide some insight on the two (unrelated) problems that have emerged in the last couple of weeks.
The first is with a BL4000 speaker.  One of the pair (other is fine) having been installed for the last 6 yrs and working fine, has decided to switch on /off very fast half a dozen times, have a rest for a random period (10 secs - 15 mins) and then have another on/off fit.  Only way to cure is to remove power which solves one problem but does not make for a great listening experience - any thoughts?
The other problem relates to our Beolink passive.  It shows a red led indicating it has power, both on the unit and the IR receiver but will not respond to any remote input to turn on.  I have spoken to local dealer who arranged for someone to phone me (left voicemail but I pressed '3' delete not '2' save so have lost contact number but essentially message was 'we can repair by replacing main board, £230+VAT' which seems a little steep to me without even trying to understand fault.  Again, any thought?
Best regards and thanks in advance for any pearls of wisdom.
Simon
									    BV10 - BL9 - BL6000 - BL2 - BS9000 - BL4000 - BL3500 - BL2000 - PC2 - BL4000 - B-Passive x 3 - BV1 - BS3000 - BL4
