is there any news about the upcoming ripping module between the beomaster 5 and beosound 5
2012 (Go ask your dealer)
Is it for the BeoSound 5 or the BeoSound 5 Encore?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Razlaw:I hope it is for Beosound 5.
The OP already says "... module between the beomaster 5 and beosound 5"
*g*
It is not for the BS5 Encore, only for the BS/BM5 and sticks to the base of BS5 as a second plate below the screen. The ripping process shall be automatic: just insert a CD and off you go.
Roger
Price?
Roger: It is not for the BS5 Encore, only for the BS/BM5 and sticks to the base of BS5 as a second plate below the screen. The ripping process shall be automatic: just insert a CD and off you go. Roger
Can the existing BS5 be used, or does it require a new version of the BS5?
There is something about B&O.....
beolion: Roger: It is not for the BS5 Encore, only for the BS/BM5 and sticks to the base of BS5 as a second plate below the screen. The ripping process shall be automatic: just insert a CD and off you go. Roger Can the existing BS5 be used, or does it require a new version of the BS5?
Yes
Yes, it's the search for high res album art that is a long process. So, if the ripping module doesn't search automaticaly on the net the good album art, we must power the laptop on and use BeoConnect or BeoPlayer. Sad...
