Latest post 10-11-2011 12:33 PM by steph. 11 replies.
Page 1 of 1 (12 items)
  • 10-09-2011 1:27 PM
    ripping module
    is there any news about the upcoming  ripping module between the beomaster 5 and beosound 5
  • 10-09-2011 3:55 PM In reply to
    Re: ripping module
    2012 (Go ask your dealer)
  • 10-09-2011 4:11 PM In reply to
    • Nio
    • Not Ranked
    • Joined on 10-01-2011
    • Posts 61
    Re: ripping module
    Is it for the BeoSound 5 or the BeoSound 5 Encore?
  • 10-09-2011 7:33 PM In reply to
    Re: ripping module
    I hope it is for Beosound 5.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 10-10-2011 5:26 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: ripping module
    Razlaw:
    The OP already says "... module between the beomaster 5 and beosound 5"
    *g*
  • 10-10-2011 10:11 AM In reply to
    • Roger
    • Top 75 Contributor
    • Joined on 03-28-2007
    • Norway
    • Posts 870
    Re: ripping module
    It is not for the BS5 Encore, only for the BS/BM5 and sticks to the base of BS5 as a second plate below the screen. The ripping process shall be automatic: just insert a CD and off you go.
    Roger
  • 10-10-2011 10:42 AM In reply to
    Re: ripping module
    Price?
    Re: ripping module
    Roger:
    Roger
    Can the existing BS5 be used, or does it require a new version of the BS5?
    There is something about B&O.....
  • 10-10-2011 1:02 PM In reply to
    Re: ripping module
    beolion:
    Roger:
    Roger
    YesSmile
  • 10-10-2011 7:10 PM In reply to
    Re: ripping module
    The "ripping" process itself is always easy. Its the finsing of proper (500x500) album art, and making qsure tagging is "correct" or to your liking, that makes the whole ripping process so tedious.
    B
  • 10-10-2011 8:07 PM In reply to
    Re: ripping module
    Sounds like I will be making another B and O purchase.
  • 10-11-2011 12:33 PM In reply to
    • steph
    • Joined on 04-16-2007
    • France
    • Posts 612
    Re: ripping module
    Yes, it's the search for high res album art that is a long process.
    So, if the ripping module doesn't search automaticaly on the net the good album art, we must power the laptop on and use BeoConnect or BeoPlayer.
    Sad...
