Latest post 10-09-2011 12:53 PM by stefan. 6 replies.
Page 1 of 1 (7 items)
  • 10-08-2011 10:10 AM
    • erandlux
    • Not Ranked
    • Joined on 11-07-2008
    • Luxemburg
    • Posts 39
    beo4, BM7000 and Beosound 5 Encore - need help
    hello guys,
    I recently bought a beo4 to control my BM7000 and BS5 Encore, but I need help to configure the beo4.  I have been through the forum but found nothing on controlling 2 audio sources in the same room that I could understand.
    Here is the situation
    My BS5 Encore is connected to the A.Tape entry of the BM7000
    The BS5 is set in CD mode, not N.MUSIC for the music storage.
    My dealer tod me I had to use the link fonction (link + CD) to power on the BS5.
    When I select the LINK fonction and the press CD, nothing happen, but when I press CD on the beo4, it turns on the CD6500 player and BS5
    The same with radio, normally, it shoul work with link-radio, but when pressing link-radio, nothing, and when selecting radio, the BM7000 turns on with radio.
    Could you please help me on the configuration, I would like to be able to
    Turn on BS5 Encore and BM7000 together with A.TAPE on BM7000 and CD on the BS5 so that ot plays music directly
    change from music mode to radio mode on the BS5 only without impact on the BM7000
    Turn on BS5 Encore and BM7000 together withe A.TAE on BM7000 and radio on the BS5 so that ot plays radio directly
    Thanks for your help
    Regards
    Eric
  • 10-08-2011 3:55 PM In reply to
    Re: beo4, BM7000 and Beosound 5 Encore - need help
    Try to program the BM7000 to A-opt 4. (hide the BS5 for the ir-instruction send by the Beo4 during option programming)
  • 10-08-2011 4:45 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Eric, Why do you want to do this? What do you want to achieve? Might be a different approach as well....?
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 10-08-2011 5:13 PM In reply to
    • erandlux
    • Not Ranked
    • Luxemburg
    • Posts 39
    What do ypu mean by different approach ?
    My installation is the following
    BM7000 is my main system where everything is connected ( cd, sony TV, beolab 4000 and a pair of old beovox)
    What I did, is connect the BS5 Encore to the BM7000 via a specific powerlink cable.
    What I would like is by pressing a single touch on the beo4' turn on eithernthe music or the radio.
    For the moment, I have to select CD on the beo4' it turns on the CD6500 and the BS5. I then have to select A.MEM on beo4 since it is connected to the A.TAPE of the BM7000.
    If I select A.AUX for TV sound, then BM7000 turns on plus BS5.
    I want them to operate separately, if you can help me on that, i am a bit lost with this beo4 configuration and options
    Thanks a lot
    eric
  • 10-09-2011 2:31 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Set your BS7000 to A.OPT 2 and your BS5E to A.OPT 4.
    Pressing CD will activate Your BG CD7000. Pressing LINK - CD will activate your BS5E.
    Hope this helps.
    Stefan
  • 10-09-2011 4:52 AM In reply to
    • erandlux
    • Not Ranked
    • Luxemburg
    • Posts 39
    Thanks Stefan,, it works fine !
    Is there a way to turn both systems together Without haviing to select A.MEM after ?
    The same with BM7000 and CD6500, when pressing CD on the beo4' the BM7000 turns on, but not the CD player.
    Eric
  • 10-09-2011 12:53 PM In reply to
    • stefan
    • Posts 1,733
    You Can use a Beo5/6 and program a macro. In my mainroom my BS9000 A.AUX input Will be activated and at the same time my BG7000 in a linkroom just hz pressing one button ón my Beo6 named PHONO. You can also use a Lintruponic box for this purpose.
    See www.lintronic.dk
    If your BG CD6500 is connected to CD socket ón Bm7000 it should start by the command CD.
    Try another input. For example try A.TAPE. Now the CD player should be activated by A.TAPE.
    The player must be connected via the standard 7pin DIN cable.
    Stefan
