hello guys,
I recently bought a beo4 to control my BM7000 and BS5 Encore, but I need help to configure the beo4. I have been through the forum but found nothing on controlling 2 audio sources in the same room that I could understand.
Here is the situation
My BS5 Encore is connected to the A.Tape entry of the BM7000
The BS5 is set in CD mode, not N.MUSIC for the music storage.
My dealer tod me I had to use the link fonction (link + CD) to power on the BS5.
When I select the LINK fonction and the press CD, nothing happen, but when I press CD on the beo4, it turns on the CD6500 player and BS5
The same with radio, normally, it shoul work with link-radio, but when pressing link-radio, nothing, and when selecting radio, the BM7000 turns on with radio.
Could you please help me on the configuration, I would like to be able to
Turn on BS5 Encore and BM7000 together with A.TAPE on BM7000 and CD on the BS5 so that ot plays music directly
change from music mode to radio mode on the BS5 only without impact on the BM7000
Turn on BS5 Encore and BM7000 together withe A.TAE on BM7000 and radio on the BS5 so that ot plays radio directly
Thanks for your help
Regards
Eric
