Latest post 10-08-2011 5:59 AM by Mr10Percent. 3 replies.
Page 1 of 1 (4 items)
  • 10-07-2011 7:32 PM
    Beolab 5 dead. Doesnt show any signs of life.
    One of my Beolab 5 doesnt show any signs of life.
    Theres no light on the top and no sound at all.
    I have tried different cables but no response at all. Its like its not getting any power.
    Is there anyone else who had has the same problem?
    Please help... i dont want to take it to a store to get it fixed... they are soooo heavy!!! :(
    /Magnus
  • 10-08-2011 12:19 AM In reply to
    Re: Beolab 5 dead. Doesnt show any signs of life.
    I've had a couple of problems with one unit - mainly because they have lapped the globe a couple of times and had some pretty dirty 240v supply at times.
    Instance 1. - replaced an internal fuse.
    instance 2. - replaced the chasis (GBP250)
    There is also quite a bit of labour to get at the internals
    The only option is to call your B&O service dept.
    10
  • 10-08-2011 2:04 AM In reply to
    Ok.. i have checked the fuse and sadly its not broken :(
    Then i guess its the chasis... do you remember how much that costed to change?
    So i know if i should take it on my insurrance or just pay B&O myself.
    /Magnus
  • 10-08-2011 5:59 AM In reply to
    Sorry, meant internal fuse, not the one associated with the power cord.
    as you said, you have tested that.
    first fault - there was a loud "pop" on night and the LED was completely extingushed. Fuse change by B&O Hanoi. Cost more to lump the thing to their workshop.
    second fault - The LED blinked Red/off every second indicating a protection fault. That was a GBP250 chasis board change.
    considering they are now 7 years old (IIRC) and have been to Indonesia, UK, Ghana, Turkey, Vietnam, Central Russia and UK again, I think they have faired rather well.
    10
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
