1st March February 2012
Latest post 11-10-2011 4:41 PM by rfc1. 12 replies.
09-29-2011 8:26 AM
rfc1
- Joined on 02-06-2008
- Posts 166
My friend just dug out his Beogram 5500, but there is no power in the machine. I have checked and changed the 500ma fuse inside as i did on my Beogram 6500, but still nothing. Any help anyone?
Sandy
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Re: Beogram 5500 problems
If the fuses was OK check the if transformer has power in and out, and go from there.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
rfc1
- Posts 166
Ok, so there is no power out from the transformer.........................
Søren Mexico
- Mexico city
- Posts 1,621
Do you have power in, and did you check the transformmer for open circiut
rfc1
- Posts 166
There is power in but i do not know about "open circuit"
Thanks for helping, Sandy
Søren Mexico
- Mexico city
- Posts 1,621
Dont give up find a friend or someone that knows a little about EL, the BG 5500 is a very nice turntable and is worth saving.
rfc1
- Posts 166
Ok, an update, we bought a 2nd hand transformer(from a beogram4500) and fitted it today, all working fine( no beomaster so no output) until i tried it this evening with my own beosystem 6500. No sound whatsoever, and i used my own mmc2 stlyus to try it....what now?
Sandy
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
The Beogram 5500 has no RIAA pre amp and neither does the Beomaster 6500!
You will need a stand alone RIAA pre amp between the two units.
rfc1
- Posts 166
joeyboygolf:
Blow me Graham, never considered this.! so correct to assume that beomaster 5500 has an RIAA pre amp then?
Just reckecked the specs re. b/master 5500 versus B/master 6500 and both seem identical.??????????
cheers Sandy.
joeyboygolf
- Posts 3,252
Beomaster 5500 has built in RIAA to match Beogram 5500 which does not.
Beomaster 6500 does not have built in RIAA to match Beogram 6500 which does!
rfc1
- Posts 166
Understood . cheers for that .
So nothing other than a beomaster 5500 will work immediately with this beogram 5500. I have ouverture and beosound 4 to hand.???
Sandy
rfc1
- Posts 166
ok Graham, onwards and upwards them!!
sandy
Page 1 of 1 (13 items)
