Latest post 10-02-2011 2:59 PM by mipe. 4 replies.
Page 1 of 1 (5 items)
  • 09-28-2011 9:44 AM
    • mipe
    • Not Ranked
    • Joined on 09-14-2011
    • Posts 13
    BEO4 Replacement remote control found
    Have anyone tryed the BEO4 replacement remote control from ebay.de?
    http://mynerdstuff.blogspot.com/2011/09/replacement-remote-for-beo4-from-bang.html
    Do anyone know if there are other replacement remote controls for BEO4, or maybee a arduino based open source version?
    I have a beovision 3-32 this was sold with BEO4 and i am not sure i can use beolink 1000 ? So i search for replacement ;)
  • 09-28-2011 10:15 AM In reply to
    • Foxtrott
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Vienna, Austria
    • Posts 500
    Re: BEO4 Replacement remote control found
    Hello mipe,
    Beo4 and Beolink1000 are using the same IR-codes, so you can use a Beolink1000 with the BV3-32.... it will work (I am using Beolink1000 and Beo4 to control my BV 3-32).
    For some of the commands you will need to use the "SHIFT" key of the BL1000, but this is no problem (for example "SHIFT"+"CD" for "DVD"). Here is a link: http://forum.beoworld.org/forums/t/38151.aspx
    I've never seen/used the remonte in the link but it seems to be a rather cheap piece of plastic... so it is better to stick with your Beolink1000.
    In case you realy want a Beo4 then I would suggest to try to find one via Beoworld (sales/wanted) section as you can get them for a fair price on the second hand market.
    Cheers!
    Foxtrott
    "The first thing we do, let's kill all the lawyers."
    Henry VI, Part 2 William Shakespeare
  • 09-28-2011 10:34 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    mipe:
    ... i am not sure i can use beolink 1000 ?
    Yes, the IR-commands are the same - but you'll have to "translate" buttons and virtual list buttons:
    Beo 4             Beolink1000 MkI & II                 Beolink 1000 MkIII & IV
    [red]             [SHIFT]+[<]                          [SHIFT]+[\/]
    [blue]            [SHIFT]+[>]                          [SHIFT]+[/\]
    [green]           [SHIFT]+[<<]                         [SHIFT]+[<<]
    [yellow]          [SHIFT]+[>>]                         [SHIFT]+[>>]
    [MENU]            [SHIFT]+[TEXT]                       [MENU]
    [LIGHT]           [SHIFT]+[LINK]                       [LIGHT]
    [GO]              [PLAY]                               [PLAY]
    [DTV]             [SATELLITE]                          [SAT]
    [DVD]             [SHIFT]+[CD]                         [SHIFT]+[SAT]
    [PC]              [SHIFT]+[STORE]                      [SHIFT]+[STORE]
    [DVD2]            [SHIFT]+[V.TAPE]                     [SHIFT]+[V.TAPE]
    [V.AUX]           [SHIFT]+[TV]                         [SHIFT]+[TV]
    [A.AUX]           [SHIFT]+[RADIO]                      [SHIFT]+[RADIO]
    [N.RADIO]         [PHONO]                              [PHONO]
    [N.MUSIC]         [SHIFT]+[A.TAPE]                     [SHIFT]+[A.TAPE]
    [FORMAT]          [PICTURE]                            [PICTURE]
    [SPEAKER]         [SOUND]                              [SOUND]
  • 10-02-2011 2:58 PM In reply to
    • mipe
    • Not Ranked
    • Posts 13
    thanks for info, i did not know that beolink 1000 can be used. Maybee my my mother in law can help me with that, she worked on Bang and olufsen in Struer ealier, and she say she know some one from b&o that might have some spare beolink 1000 remoites :)
  • 10-02-2011 2:59 PM In reply to
    • mipe
    • Not Ranked
    • Posts 13
    thanks, this will not be a problem, so i think i will got find a beolink 1000 instead of the cheap german remote in the link ;)
