Latest post 09-26-2011 1:22 PM by Daniel. 1 replies.
Page 1 of 1 (2 items)
  • 09-26-2011 1:07 PM
    • EeePee
    • Not Ranked
    • Joined on 09-26-2011
    • Posts 1
    A/V without Remote control?
    Hi!
    I have a LX2800 and don't have the remote control.
    I want to play 8-bit nintendo with it and I tried it in with scart and ant.Cable.
    It seems that with the "step" button you can't go to the A/V mode or is it possible?
    Thanks!
    Filed under: ,
  • 09-26-2011 1:22 PM In reply to
    • Daniel
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Svinarp, Sweden
    • Posts 1,284
    Re: A/V without Remote control?
    Just checked in the manual, you need a remote control. The original one is called Video Terminal, but an AV Terminal should work as well. The manual is available on this site for silver and gold members. By the way, welcome!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
