Hmm, this is getting a Dutch topic......
I think the price for this belt is not that high at the dealer, and you are sure that you get the right size. Since the mechanism is a pain in the *** to take apart, I would use the original part. In that case you are sure that it has a perfect fit.
@ Leslie, thanks for the link
! They can supply the belt for BeoGram 1000, 1200 etc. I did not know there was a supplier that could supply this!
En natuurlijk met de allervriendelijkste groeten!!
