Latest post 09-19-2011 3:04 PM by kawo. 9 replies.
Page 1 of 1 (10 items)
  • 09-19-2011 7:55 AM
    Give me a reason
    I need a new tv.
    My ideas (and my budget):
    32" beovison 10 or
    55" led Smart tv by Samsung
    Give me a good reason to buy The fantastic beovision 10 (small) or The beautiful (but not a masterpiece) big Samsung led tv with a super tiny frame!
    Thanks!
  • 09-19-2011 9:39 AM In reply to
    • Tayne
    • Not Ranked
    • Joined on 05-31-2007
    • Posts 23
    Re: Give me a reason
    The samsung does have a tiny frame. But whats more important to you? The frame or the quality.....
    Also, i advise you listen to the speaker system in-built in the samsung, you will soon make your mind up! :-)
  • 09-19-2011 9:49 AM In reply to
    Ok, i already have The beolab 8000 thus I just need a central speaker... To match the quality of the beovision 10.
    Moreover the sound of beovision 10 I think is worst than my beovision 1
    The only reason that I can find for now is the stunning design of the beovision 10
  • 09-19-2011 10:01 AM In reply to
    • hotknife
    • Top 150 Contributor
    • Joined on 02-03-2008
    • Solingen/Germany
    • Posts 552
    Together with you BL8000 you only use the speaker of the BV10 as central speaker. I do not think the inbuild speaker of the BV10 will make a bad performance. If you use the BV10 without add. speaker, I would agree, but only as central speaker....
    BeoVision 8-40, ATV2, BeoSound 4, Front BeoLab 9, Rear Beolab 4000 MKII, Beo 4
  • 09-19-2011 10:23 AM In reply to
    If you want to spend that amount of money, and looking at two completely different TV's...
    You have to ask yourself, which one do you want/need?
    If I was set on a 55" TV in a big room to enjoy as a home cinema with surround sound, I wouldn't look at the 32" BV10 to begin with.
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 09-19-2011 10:26 AM In reply to
    Think about it this way...
    The 55" has an area almost 3 times as big as the 32"!
    -Andreas
  • 09-19-2011 11:24 AM In reply to
    If your room is big enough - buy the larger TV; 32 inch that was in the 80s;
    bigger screen needs good qualitiy of your TV-signal; if you don't get HD be carefull...
    regards Elmar
  • 09-19-2011 12:53 PM In reply to
    You prefer a VERY BIG SsangYong Rodius or little (for exemple) SLK or Audi TT/A3?
    You cannot measure style in weight....
  • 09-19-2011 12:56 PM In reply to
    November35:
    How can it be style at 55"?
    And not everything is about style nor weight.
    -Andreas
  • 09-19-2011 3:04 PM In reply to
    • kawo
    • Joined on 04-17-2007
    • Posts 516
    Size matters :-)
    If your viewing distance allows or "need" a 55" TV set, go for it! I had a BV3-32 at the same place where the BV4-50 is now....never ever I would go back to 32" screen. The Samsung TV's are not bad at all and from a design point of view I think the thin frame is quite nice.  For your, the BV 10 is an icon, but size matters.... :-)
    _________________________________________________________________________
    BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
