1st March February 2012
Latest post 09-19-2011 3:04 PM by kawo. 9 replies.
09-19-2011 7:55 AM
Tayne
- Joined on 05-31-2007
- Posts 23
The samsung does have a tiny frame. But whats more important to you? The frame or the quality.....
Also, i advise you listen to the speaker system in-built in the samsung, you will soon make your mind up! :-)
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
If you want to spend that amount of money, and looking at two completely different TV's...
You have to ask yourself, which one do you want/need?
If I was set on a 55" TV in a big room to enjoy as a home cinema with surround sound, I wouldn't look at the 32" BV10 to begin with.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
bayerische
- Helsinki, Finland
- Posts 3,593
Think about it this way...
The 55" has an area almost 3 times as big as the 32"!
-Andreas
f5434964
- Joined on 07-21-2010
- Posts 198
If your room is big enough - buy the larger TV; 32 inch that was in the 80s; bigger screen needs good qualitiy of your TV-signal; if you don't get HD be carefull...
regards Elmar
November35
- Joined on 07-09-2008
- Novara, Italy
- Posts 53
You prefer a VERY BIG SsangYong Rodius or little (for exemple) SLK or Audi TT/A3?
You cannot measure style in weight....
bayerische
- Helsinki, Finland
- Posts 3,593
November35:
How can it be style at 55"?
And not everything is about style nor weight.
-Andreas
kawo
- Joined on 04-17-2007
- Posts 516
Size matters :-)
If your viewing distance allows or "need" a 55" TV set, go for it! I had a BV3-32 at the same place where the BV4-50 is now....never ever I would go back to 32" screen. The Samsung TV's are not bad at all and from a design point of view I think the thin frame is quite nice. For your, the BV 10 is an icon, but size matters.... :-)
_________________________________________________________________________
BV4-50, Beosystem 3, Beolab 5, Beolab 3, BV3-32, BV1, BS9000, Beolab 4, Beolab 2000, Beo4 Cinema
Page 1 of 1 (10 items)
