Latest post 09-20-2011 2:32 AM by DrDimitris. 22 replies.
Page 1 of 1 (23 items)
  • 09-18-2011 5:06 AM
    How to get audio when connecting the new Apple TV to BeoVision7?
    I cannot get audio from my TV when the new Apple TV is connected.
    I have tried connecting the optical lead from the Apple box to the TV via a optical to digital coax converter that is plugged into the orange socket on the back, but still nothing!
    Any idea's please...?
  • 09-18-2011 7:16 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: How to get audio when connecting the new Apple TV to BeoVision7?
    Topsparks:
    More details about your B&O TV and the rest of your config, please!
  • 09-18-2011 7:34 AM In reply to
    • JC
    • Joined on 04-16-2007
    • Yorkshire / UK
    • Posts 621
    Having the same problem!!
      ATV is plugged into an HDMI to component convertor, this then into component sockets on the TV and audio into a scart convertor. Picture is perfect but there is no sound. Even plugging the audio into the audio jacks directly makes no difference.
      Is this your set up Topsparks?
      Jonnie
  • 09-18-2011 7:42 AM In reply to
    I have picture fine. The audio is connected to one of the orange digital coax inputs on the tv (top right on back) via an optical to digital converter, the optical cable being connected to the Apple TV box.
  • 09-18-2011 7:46 AM In reply to
    No, it's for a customer. I have spoken to B&O technical who have talked me through configuring the correct inputs and it was their view that the Apple TV box should have an option to set the audio output to optical, however, under the Apple settings there is no option to change it. The HDMI option cannot be changed from auto and the audio otions are either auto or 16 bit. Spoke to Apple technical and they advised that the TV was not comatable and I should plug it into a seperate home theatre system. B&O advise this is bo**ox...
  • 09-18-2011 8:00 AM In reply to
    What Beovision do you have? If you have connected your ATV 2 via HDMI to your TV there is no need for an additional audio connection at all!
    /Räuber
  • 09-18-2011 8:50 AM In reply to
    • mhw
    • Top 500 Contributor
    • Joined on 06-29-2007
    • Norway
    • Posts 207
    • Gold Member
    Which version of the Beovision 7 is it? If I remember correctly the first versions (MK l and ll I think) didn't support standard 2-channel PCM sound through the digital inputs, only DTS and DD. You had to use analog audio for 2-channel sound...
    Try playing a movie with DD 5.1 on the Apple TV.
    Magnus
  • 09-18-2011 9:25 AM In reply to
    Buy this and forget apple overpriced crap. Whistle
    BS 1, BeoCom 2, 2x LC 2, Form 2,  BS 2, BS 3, 2x Beo 4, BS 5, BM 5, BL 5,Beo 6, BS 6, 2x A8, BV 8-40, BL 8000, 3x A9 Keyring, Serenata, BeoTime, BeoTalk 400
  • 09-18-2011 9:32 AM In reply to
    I'm connecting to a beovission7. It does NOT accept audio through the HDMI cable.
  • 09-18-2011 9:36 AM In reply to
    Have tried changing the Dolby setting, but makes no difference, still NO audio.
    Where did you connect the analogue audio to?
  • 09-18-2011 10:30 AM In reply to
    hi, does it have genuine hdmi fitted or is there a dvi to hdmi convertor?  If it does dvi doesnt carry sound!
  • 09-18-2011 11:02 AM In reply to
    I am aware that the HDMI cable wil not carry audio (it's connected through a DVI adaptor on the TV), that's why I'm trying to use the optical cable from the ATV.
  • 09-18-2011 11:34 AM In reply to
    So try the sound with DD 5.1 material from ATV 2, p.e. a rented film. I assume you will hear the sound and so your BV 7 cannot handle PCM sound. An firmware update can solve this problem.
    Regards
    Räuber
  • 09-18-2011 11:43 AM In reply to
    Changing the Dolby setting makes no difference...
  • 09-18-2011 12:19 PM In reply to
    I didn't mean the dolby settings of the ATV 2, but the sound MATERIAL send to the BV!
  • 09-18-2011 12:34 PM In reply to
    Please explain how to do this...
  • 09-18-2011 12:50 PM In reply to
    P.e. Youtube videos and music from Itunes library is sent in PCM from ATV 2 to BV 7 and this could be the problem because some BV 7 without HDMI inputs cannot handle the PCM audio format.
    But a rented video from the ITunes store has normally Dolby Digital 5.1 audio format and this should be played by every BV 7.
    /Räuber
  • 09-18-2011 2:52 PM In reply to
    Raeuber:
    Right!
    This has been discussed several times. An update (DSM module) will solve the problem. Unfortunatly it's not a software update.
  • 09-19-2011 4:43 AM In reply to
    What is a DSM module and where do I get one please?
  • 09-19-2011 7:23 AM In reply to
    It's the sound module in your tv. It needs an update with a newer chip. Ask your dealer. Smile
  • 09-19-2011 10:31 AM In reply to
    DoubleU:
    Right!
    Does anyone know if the DSM module is available for Beovisions 7-32 MK II?? If yes which part No. should i order and what shall i expect pricewise??
    -Dimitris
  • 09-19-2011 6:41 PM In reply to
  • 09-20-2011 2:32 AM In reply to
    DoubleU:
    Thank you Doubleu Wink. I somehow missed this...Hmm
    -Dimitris
