Latest post 10-20-2011 11:40 PM by Søren Mexico. 34 replies.
Page 2 of 2 (35 items) < Previous 1 2
  • 10-18-2011 10:36 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beogram 4004 & Beomaster 4400 Maintenance and speaker ideas.
    Søren Mexico:
    Still waiting for mine to arriveSad
    Don't worry, it is worth the wait!
    Evan
  • 10-20-2011 11:40 AM In reply to
    • Gene
    • Not Ranked
    • Joined on 09-17-2011
    • Topeka, Kansas USA
    • Posts 26
    Just purchased 2 pairs of S75's. No stands, but the speakers are perfect. I am the IT guy at a metal fabrication company. I have pictures of the stands, but no other info. Does anyone have measurements of the stand and the angle the speaker sits at? If so, I can fab a couple of pair for me or anyone else who needs them.
  • 10-20-2011 11:56 AM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    They're adjustable.  From the service manual:
    "Adjust the tilt of the speaker so that the lower portion of the cabinet is perpendicular to a straight line to the listening position."
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 10-20-2011 1:06 PM In reply to
    • Gene
    • Not Ranked
    • Posts 26
    I see from the pics how to adjust the angle, but how does the bar that screws to the back of the speaker accomodate the different angles? Does it pivot?
  • 10-20-2011 5:14 PM In reply to
    Read Here
    And here is for S45, check the foot print of your speaker, make the foot accordingly, if your speakers has threaded holes, check size (M5) if not you will have to make some and insert a threaded insert from the inside of the speaker (Home Depot) or use wood screws, the holes in my S45s are exact in the middle of the speakers hight.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 10-20-2011 5:16 PM In reply to
    I forgot, the tilt angle of the upright is 3 degrees
  • 10-20-2011 7:06 PM In reply to
    One more time, my speakers bottom is 250 Mm from the floor
  • 10-20-2011 8:54 PM In reply to
    • Gene
    • Not Ranked
    • Posts 26
    Soren-
    How does the top bar, where the screws attach the stand to the speaker allow for a change of angle?
  • 10-20-2011 11:36 PM In reply to
    Bigger holes than the screwes or bushes you put there, give a 1.0 Mm gap or better 1.5 Mm to be more flexible. Its not that important just give gap.
  • 10-20-2011 11:40 PM In reply to
    Forgot again, horisontal and vertical gap
