1st March February 2012
Latest post 10-20-2011 11:40 PM by Søren Mexico. 34 replies.
Evan
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.06.67/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
Re: Beogram 4004 & Beomaster 4400 Maintenance and speaker ideas.
Søren Mexico:
Still waiting for mine to arrive![Sad](http://forum.beoworld.org/emoticons/06.gif)
Don't worry, it is worth the wait!
Rich
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.59.19/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
They're adjustable. From the service manual:
"Adjust the tilt of the speaker so that the lower portion of the cabinet is perpendicular to a straight line to the listening position."
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Gene
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.84.32/avatar.jpg)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 09-17-2011
- Topeka, Kansas USA
- Posts 26
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
I see from the pics how to adjust the angle, but how does the bar that screws to the back of the speaker accomodate the different angles? Does it pivot?
Søren Mexico
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.50.93/avatar.jpg)
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Read Here
And here is for S45, check the foot print of your speaker, make the foot accordingly, if your speakers has threaded holes, check size (M5) if not you will have to make some and insert a threaded insert from the inside of the speaker (Home Depot) or use wood screws, the holes in my S45s are exact in the middle of the speakers hight.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Søren Mexico
- Mexico city
- Posts 1,621
I forgot, the tilt angle of the upright is 3 degrees
Søren Mexico
- Mexico city
- Posts 1,621
One more time, my speakers bottom is 250 Mm from the floor
Gene
- Posts 26
Soren-
How does the top bar, where the screws attach the stand to the speaker allow for a change of angle?
Søren Mexico
- Mexico city
- Posts 1,621
Bigger holes than the screwes or bushes you put there, give a 1.0 Mm gap or better 1.5 Mm to be more flexible. Its not that important just give gap.
Søren Mexico
- Mexico city
- Posts 1,621
Forgot again, horisontal and vertical gap
