Latest post 01-29-2012 10:10 AM by kimhav. 10 replies.
Page 1 of 1 (11 items)
  • 09-16-2011 5:31 PM
    • kimhav
    • Top 500 Contributor
    • Joined on 09-03-2007
    • Sweden
    • Posts 127
    ML/CAT wiring projects
    Hello,
    As I'm going to wiring up a house that we're currently renovating I've been looking for ideas, diagram, suggestion for wiring up a house; aware that this is for indivual taste. But, for my own project I'm looking to connect kitchen, living room, dinning room, office, library, bedroom and bathroom. In the link system there will be BS9000, BV10, BeoPort, Encore, BL8000, BL3500. So kind of interested of how other done similar wiring.
    Filed under: , ,
  • 09-17-2011 12:56 AM In reply to
    Re: ML/CAT wiring projects
    For ML you can use CAT wires as well, but there must not be any active components in this ML network ( routers, switches,...). The Encore has no ML, but Ethernet. In my opinion you should run 2 CAT wires to each port: one for ML and the other for a standard Ethernet network. I have the same in my house. Once ML to Ethernet adapters are available (Beonet) you can convert ML to Beonet.
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 09-17-2011 8:05 AM In reply to
    • Paul
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    Interesting project.  I want to do the same thing.  I am looking for schemastics and pinouts. Also I would like to know where to buy the ML connectors preferable on ebay
  • 09-17-2011 8:54 AM In reply to
    I have got standard wallmounted network sockets for RJ45 and then my B&O dealer made some RJ45 to ML cables for almost nothing. One Beonet is available I simply exchange these cables.
  • 09-17-2011 10:14 AM In reply to
    if your not on a tight budget I recommend to most to run 3-4 Cat7 lines to each location they think they may put equipment, wether it be B&O or not. That will allow for multiple configurations and sources for most scenarios now and in the near future. For the little more you'll pay now, you won't be cornered later in your decision making.
    BV7-40 MKIV, BeoVision Avant 32, BeoVision 8-32, BeoLab Penta MKIII, BeoLab 6000 x 3, BeoSound 9000 MKIII, BeoLab 7-4, BeoSound 4000, BeoPort, BeoVox S45-2, ML/MCL Convertors, A8's & Form 2's.
  • 09-17-2011 1:52 PM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Well, my plan is to wire up each of the drops with minimum CAT7 cabling to ensure that I can have both a ethernet and masterlink connectivity.
    What I'm looking for are following:
    • Combo PL + 230V to drive BL8000 or plain single PL jacks
    • Combo ML + 230V to drive BL3500 or plain single ML jacks
    For above I'm intersted of suggestions for both wall and floor mounted jacks and what else of creativity fellow BW users has to suggest. So highly interested of pictures of above including how you done on your own side.
    For example how has other solved to hide the power supply for BeoCom and BeoTalk? Are you using plain PVC coundit pipes? In the current house I've managed to get 4xCAT5e cables into 20mm PVC coundit pipes for my normal ethernet (not big fan of wireless if I can avoid it).
    Filed under: , ,
  • 09-21-2011 5:55 AM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Well, here is the init draft of the unit placement in the current building; the image shows (from top down) 2nd floor, first floor and the tiny basement.
    The plan is to wire up the house with a star network using double CAT7 cabling to be used for Ethernet and BeoNet; then the idea was to wire up one seperate segment for the old MasterLink; this would then not be a star network. Guess that I'm not the only one which has headache with mixed old units and as well waiting for the new BeoNet
    MasterLink, CAT7
    Filed under: , , ,
  • 09-21-2011 5:37 PM In reply to
    • kimhav
    • Sweden
    • Posts 127
    What I would like to verify with above ML-schematic if it's correct from the perspective that I'm able to play music on the BS9000 and 1) make use of only the left set of BL8000 and as well 2) making use of all 4 BL8000. At least it's my understanding that the BS9000 should be able to make use of the speakers connected to the BV10; but then again; does it work with above examples? Also, what option value should be used for the various units?
  • 10-09-2011 3:24 AM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Well, been looking around and as it's an old house that I want to build the digital ML I'm going for bakelite sockets; here is how the antenna jacket looks like:
    and the modular jacket (cat6a):
  • 10-09-2011 3:38 AM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Well, you can make use of RJ-45 connectors instead of ML connectors; B&O already now offers such cabling; RJ-45 to ML connectors. Check this thread for additional information.
  • 01-29-2012 10:10 AM In reply to
    • kimhav
    • Sweden
    • Posts 127
    Well, updated the schematics for the ML-network to make use of proper star based network; all cabling will be done using dublex CAT7 cable. So now looking into making use of LexCom distribution central and the ML and Ethernet modules (gigabit are now available). So the standard LexCom DPM distribution central looks like a good starter. Any hints and tips regarding config for this central?
