Latest post 09-17-2011 6:12 AM by westonetwo. 15 replies.
Page 1 of 1 (16 items)
  • 09-14-2011 5:52 PM
    BEO4 setup - radio, cd, a tape functions don't seem to work?
    Trying to set up a beo4 previously only used with a MX4000, I've tried the List+Standby button then selecting option then a.opt and 1, the light on my beosound 1 then blinks.
    However, only the TV, Sat, V Tape and Light buttons seem to work I'm getting nothing from Radio, CD, A Tape, Record or AV, could someone tell me how to reanable these buttons?
    Many Thanks Again!
  • 09-14-2011 6:10 PM In reply to
    • kai
    • Top 500 Contributor
    • Joined on 11-16-2008
    • Posts 81
    Re: BEO4 setup - radio, cd, a tape functions don't seem to work?
    You will need to put it in option v opt 2, then you should be able to bring through your cd radio :)
  • 09-14-2011 6:23 PM In reply to
    Thanks kai, I've tried to do this but it doesn't seem to have fixed the problem.  But I'm really new to all of this and might have done something wrong. [:'(]
  • 09-14-2011 6:27 PM In reply to
    Are video and audio sources connected by Masterlink or separate systems?
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 09-14-2011 6:32 PM In reply to
    Sorry, I should probably have described this more clearly, I'm trying to use a beo4 with a beosound 1, but the aforementioned buttons don't work and therefore I can't operate the beosound 1.
    I've recently purchased the beo4 off someone who has exclusively used the remote with an mx4000.
    I wondered if I had to add a.setup?
  • 09-14-2011 6:34 PM In reply to
    I only have one B&O unit the Beosound 1
  • 09-14-2011 10:05 PM In reply to
    I just tried a.opt 1 on my Beosound 1 and all worked fine. Your Beosound 1 works fine using the bittons on it, correct?
  • 09-15-2011 2:52 AM In reply to
    Works fine using the buttons on it.
  • 09-15-2011 6:42 AM In reply to
    • hfat
    • Joined on 05-18-2010
    • Austria
    • Posts 176
    • Gold Member
    Hello,
    I think you should try to use a different audio config for the beo4. Setting A.Mode or V.Mode configures the device how it responds to IR commands and not the BEO4 which commands it sends:
    Standby+List
    select Config
    select Audio
    select Basic.
    It's worth a try. (BEO4 guide, page 14)
    hfat
  • 09-15-2011 1:54 PM In reply to
    Thanks hfat
    When I press Standby+List I only get three options
    Option?
    <press list again>
    Add?
    <press list again>
    Remove?
    I don't seem to get the option to select Config?
    Is this hidden?
  • 09-16-2011 1:00 AM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    Probably your BEO4 has an older SW. For the moment, i'm afraid, I have no clue.
    hfat
  • 09-16-2011 2:34 AM In reply to
    I suspect that the Beo4 has keyboard problems. The remote is faulty.
    As far as I know, there is no way to disable the buttons on the remote and no way to enable them.
    The setting up  functions on the remote merely control what additional functions are present when you press LIST (a quicker ADD/REMOVE function)
    View the IR emitters with your mobile phone camera and press the offending buttons - you should see the IR diodes emit the signal if the buttons are working.
    Regards Graham
  • 09-16-2011 1:11 PM In reply to
    • Emil
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    There is also the possibility that your Beo4 has been set to a permanent link mode. To disable press standby list, then list again until you reach "config" (not sure what to do if config is not present on your remote) and then 2 0 0 2.
    Inflagrante
  • 09-16-2011 5:15 PM In reply to
    Thanks everyone for the help, doesn't look like there is an easy answer though.
    Might look for another Beo4.
  • 09-17-2011 5:37 AM In reply to
    • hfat
    • Austria
    • Posts 176
    • Gold Member
    Did you check the IR-emitter with your handy Camera?
  • 09-17-2011 6:12 AM In reply to
    I did it shows several of the buttons are not working :-(
