1st March February 2012
Latest post 09-17-2011 6:12 AM by westonetwo. 15 replies.
09-14-2011 5:52 PM
westonetwo
![](/utility/anonymous.gif)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 09-08-2011
- Posts 17
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
BEO4 setup - radio, cd, a tape functions don't seem to work?
Trying to set up a beo4 previously only used with a MX4000, I've tried the List+Standby button then selecting option then a.opt and 1, the light on my beosound 1 then blinks.
However, only the TV, Sat, V Tape and Light buttons seem to work I'm getting nothing from Radio, CD, A Tape, Record or AV, could someone tell me how to reanable these buttons?
Many Thanks Again!
kai
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
- Joined on 11-16-2008
- Posts 81
Re: BEO4 setup - radio, cd, a tape functions don't seem to work?
You will need to put it in option v opt 2, then you should be able to bring through your cd radio :)
westonetwo
- Posts 17
Thanks kai, I've tried to do this but it doesn't seem to have fixed the problem. But I'm really new to all of this and might have done something wrong. [:'(]
Razlaw
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.28.75/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Joined on 04-24-2007
- Illinois
- Posts 1,770
![Silver Member](/Themes/beotheme1/images/roleicons/3cca3820-1e81-47d8-9399-96612b7eabf0.gif)
Are video and audio sources connected by Masterlink or separate systems?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
westonetwo
- Posts 17
Sorry, I should probably have described this more clearly, I'm trying to use a beo4 with a beosound 1, but the aforementioned buttons don't work and therefore I can't operate the beosound 1.
I've recently purchased the beo4 off someone who has exclusively used the remote with an mx4000.
I wondered if I had to add a.setup?
westonetwo
- Posts 17
I only have one B&O unit the Beosound 1
Razlaw
- Illinois
- Posts 1,770
I just tried a.opt 1 on my Beosound 1 and all worked fine. Your Beosound 1 works fine using the bittons on it, correct?
westonetwo
- Posts 17
Works fine using the buttons on it.
hfat
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 05-18-2010
- Austria
- Posts 176
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
Hello,
I think you should try to use a different audio config for the beo4. Setting A.Mode or V.Mode configures the device how it responds to IR commands and not the BEO4 which commands it sends:
Standby+List
select Config
select Audio
select Basic.
It's worth a try. (BEO4 guide, page 14)
hfat
westonetwo
- Posts 17
Thanks hfat
When I press Standby+List I only get three options
Option?
<press list again>
Add?
<press list again>
Remove?
I don't seem to get the option to select Config?
Is this hidden?
hfat
- Austria
- Posts 176
Probably your BEO4 has an older SW. For the moment, i'm afraid, I have no clue.
hfat
joeyboygolf
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.69/avatar.jpg)
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
I suspect that the Beo4 has keyboard problems. The remote is faulty.
As far as I know, there is no way to disable the buttons on the remote and no way to enable them.
The setting up functions on the remote merely control what additional functions are present when you press LIST (a quicker ADD/REMOVE function)
View the IR emitters with your mobile phone camera and press the offending buttons - you should see the IR diodes emit the signal if the buttons are working.
westonetwo
- Posts 17
Thanks everyone for the help, doesn't look like there is an easy answer though.
Might look for another Beo4.
westonetwo
- Posts 17
I did it shows several of the buttons are not working :-(
Page 1 of 1 (16 items)
