when pluged in only the panel lights work but nothing else does. Pressing load does not do anything. there are no sounds no moters running Cant find a fuse of any sort hope someone can help
Is the glass panel still in place. Maybe you could try to remove the glass panel and touch the rubber pins manually?
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Thank you for your reply Leslie. I have tried what you said but but no luck
If i push " load" the light comes on but nothing else happens.
If i push "play" the same happens.
Any suggestions welcome.
Goodman123
Check for cracked solder joints at the regulators.
Sorry Martin but what & where are the regulators?.Bit of novice but learnig fast.
goodman 123
