Latest post 09-14-2011 11:52 AM by goodman123. 4 replies.
Page 1 of 1 (5 items)
  • 09-12-2011 8:00 AM
    Beocord 3500 type 4967
    when pluged in only the panel lights work but nothing else does. Pressing load does not do anything. there are no sounds no moters running  Cant find a fuse of any sort  hope someone can help
    Filed under:
  • 09-13-2011 4:25 PM In reply to
    Re: Beocord 3500 type 4967
    Is the glass panel still in place. Maybe you could try to remove the glass panel and touch the rubber pins manually?
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 09-14-2011 10:22 AM In reply to
    Thank you for your reply Leslie.  I have tried what you said but but no luck
    If i push  " load" the light comes on but nothing else happens.
    If i push "play" the same happens.
    Any suggestions welcome.
    Goodman123
  • 09-14-2011 10:39 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Check for cracked solder joints at the regulators.
  • 09-14-2011 11:52 AM In reply to
          Sorry Martin but what & where are the regulators?.Bit of novice but learnig fast.
    goodman 123
