Latest post 09-13-2011 3:37 PM by Medogsfat. 6 replies.
Page 1 of 1 (7 items)
  • 09-11-2011 10:41 PM
    Beogram RX 5773 - Bad transformer
    Beogram RX 5773 - What is the voltage output of the transformer?
  • 09-12-2011 2:50 AM In reply to
    Re: Beogram RX 5773 - Bad transformer
    There is a possible transformer available today on eBay, item number 280733946081.
    Compare the picture with yours and this may be a suitable replacement for you .
    Ron
  • 09-12-2011 2:54 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Keither57:
    If memory serves me the output is 18V DC.
    Ron is correct - the transformer on ebay will work perfectly well with a RX, the 1800 is the same basic model.
    Chris.
  • 09-12-2011 10:05 PM In reply to
    Thanks for the quick responses.
    I inherited this TT and it looks like a drink (probably a beer) was spilled on it.
    I am looking for the voltage so that i can try it before spending money on it, if it works and the cartridge is good then i will definitely spend some dough on a beo transformer.
    I doubt that it is DC output as i see a diode rectifier on the board.
    Beogram RX 5773
  • 09-13-2011 2:36 AM In reply to
    I'm sure Chris meant to type AC Smile
    We don't apparently have the RX service manual on site, but both BG1800 (the predecessor) and RX2 (the successor) show a 12V regulator (7812) after the transformer and the rectifier. So a 18V transformer secondary sounds about right. After the rectification, the 7812 needs at least 3-4 volts headroom to do its job and produce a steady 12 V output.
    -mika
  • 09-13-2011 6:44 AM In reply to
    • Dillen
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    If you replace the transformer, don't forget to check the mains voltage setting too.
  • 09-13-2011 3:37 PM In reply to
    • Medogsfat
    • Posts 4,045
    tournedos:
    He did Embarrassed
    I can feel a band name coming on................
