I have a specific problem:
When I connect the older Beocord casette player to my beomaster 4500, the tape sound is constantly playing through the left speaker at a fixed level, the volume controlling has no effect (only for the right speaker). It is connected through Tape 1 input, but the same problem arises even when connected to Aux input. And if the beocord is playing, even if I change to phono, cd, radio on the beomaster, the tape overrules the other signals (from cd, radio, vinyl) the tape-sound i still there. When I use headphones connected to the beocord, everything is OK.
What is wrong - do the beocord 5000 and beomaster not fit toghether (why not?)?
Regards, Per-Ola
