Hello all,
I am looking for a way to enable a couple of Scenes triggered from my MLGW consisting of both lighting and sound.
One scene would be for example "Dinner Party" where the lighting is set according to the Dinner Table and the background music is set at a slightly lower level.
A second example scene would be "Party" where again the lighting is set and the music volume is set to a considerably higher basic setting.
I have no difficulties with the lighting scenes, but I am struggling to find an easy way of setting the default volume for each scene, for instans volume level 30 for "Dinner Party" and volume level 60 for "Party".
I have seen that I can add a Volume Up command, and this could be a possible way ahead, but I idealy would like to find a way of "sending Volume = 30" of Volume = 60"
The device is a BV9 but this should not make any big difference from a Macro perspective.
Any ideas ?
//Rolf
