Latest post 09-23-2011 6:52 AM by Rolf. 8 replies.
Page 1 of 1 (9 items)
  • 09-07-2011 5:36 AM
    • Rolf
    • Not Ranked
    • Joined on 04-21-2007
    • Stockholm, Sweden
    • Posts 63
    Macro assistance MLGW
    Hello all,
    I am looking for a way to enable a couple of Scenes triggered from my MLGW consisting of both lighting and sound.
    One scene would be for example "Dinner Party" where the lighting is set according to the Dinner Table and the background music is set at a slightly lower level.
    A second example scene would be "Party" where again the lighting is set and the music volume is set to a considerably higher basic setting.
    I have no difficulties with the lighting scenes, but I am struggling to find an easy way of setting the default volume for each scene, for instans volume level 30 for "Dinner Party" and volume level 60 for "Party".
    I have seen that I can add a Volume Up command, and this could be a possible way ahead, but I idealy would like to find a way of "sending Volume = 30" of Volume = 60"
    The device is a BV9 but this should not make any big difference from a Macro perspective.
    Any ideas ?
    //Rolf
    Filed under:
  • 09-07-2011 7:43 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Macro assistance MLGW
    Sorry, no idea about a volume = xx setting - BUT using volume up:
    If volume max = 100 you would need to go volume down 100 times, then up 30 for dinner party (or up 60 for party), because you don't know the volume starting point.
    I wonder how much time it takes to send these many commands?
    Ralf
    PS: No MLGF here, just trying to help...
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 09-07-2011 8:12 AM In reply to
    • Rolf
    • Not Ranked
    • Stockholm, Sweden
    • Posts 63
    The problem with this solution is that in many cases it is impossible to know what the actual volume level is before adjusting it up or down in a number of steps. The only way would be to turn the device off and on and base the settings on the default audio volume setting.
    This might be the last resort but hopefully somebody has some ideas.
  • 09-07-2011 8:17 AM In reply to
    • kallasr
    • Posts 1,077
    But that is exactly what I intended to solve: if audio is MAX 100, you need to go volume down 100 times to start at zero.
    If volume max is 60, 60 times vol. down to reach the 0 point...
    Ralf
  • 09-07-2011 10:17 AM In reply to
    Rolf:
    Does that BV respond to the familiar "reset" command? You could store a known volume setting (preferably the lowest of the required scenes, I guess) as default. Then send RESET followed by the required number of vol-ups for each scene. I believe slow volume changes would be more enjoyable in any case.
    I don't think any B&O devices have a way of directly commanding a certain volume setting.
    -mika
  • 09-07-2011 11:06 AM In reply to
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    I have had the same problem.
    There is no way to set it without individual key presses.
    I have been down this road.
    There is no way to set a distinct volume number. You must press the volume button. I even tried to manipulate the mlgw so that it would 'hold' the volume button down.
    No luck.
    Let me know if you figure this out.
    MJM
    I'm ready for something new that I actually want to buy!
  • 09-07-2011 12:52 PM In reply to
    you must first know is the  volume number programmed in bv9 (you can see that when you turn on the tv)
    example foto (12 times the volume down or up) in the same macros can introduce light
  • 09-07-2011 1:03 PM In reply to
    This is my "dinner" macro photo
    you can use and AST do exchange between speakers
  • 09-23-2011 6:52 AM In reply to
    • Rolf
    • Not Ranked
    • Stockholm, Sweden
    • Posts 63
    After some further testing I think that I have found the solution I was looking for.  The actual macro commands can be seen in the following screenshot.
    Rows 1 and 2 set the correct light settings
    Rows 3 and 4 are for those of you that have an AST Speaker setup, Function_1 equals "Preset 1" from the BEO5/6 and is typically the first AST Listening Preset. Function_6 would set AST back to the default TV setting and Function_7 is the Cinema setting.
    Row 5 is the key in the solution as it "resets" the volume setting to the TV/Audio level default setting (i.e. same as at TV/Audio startup level), this means that irrespective of what the TV/audio has been used for before the Macro is activated it will be set to it default volume setting and from this known volume level (in my case 40) it is easy to step up or down the volume level as needed since we know where we are starting at all times now.
    Rows 6 and onwards are simply a number of Volume steps (UP or DOWN), DOWN in this case
    Good Luck !
    //Rolf
    Filed under:
