Latest post 09-05-2011 3:44 PM by yachadm. 6 replies.
Page 1 of 1 (7 items)
  • 08-31-2011 3:18 PM
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    BeoCenter 9500 problem
    Hi all,
    On this BC9500 - when adjusting the volume up or down, a distorted "bleep" is heard. No matter which source is selected.
    Any ideas?
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 08-31-2011 5:22 PM In reply to
    Re: BeoCenter 9500 problem
    A new one on me!
    Regards Graham
  • 09-01-2011 3:56 AM In reply to
    Hello Menahem,
    Is it on both channels?
    I would suspect the 54IC3 / TC9177 as a source. It's located after the input source switch.
    Probably hard to get - I never ran across that one. Internet tells it's a Toshiba. Looks like a digitally controlled pot only.
    Eventually 54IC1 (right) or IC2 (left)/ 4558 that's actually creating the attentuation.
    And I never had a BC9500 - now it's the first on my wishlist meanwhile...
    I suppose you have the SM - if not, let me know.
       Gunther
  • 09-01-2011 4:26 AM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    I have a mediocre copy of the SM - if you have really clear one, that would be great,
    Yes, I see this IC - I'll check it.
    If you find a 9500, make sure that the laser works fine at 50mV. If the laser current has been boosted, it will become a beautiful doorstop very soon. There are NO new lasers available anywhere.
  • 09-01-2011 5:00 AM In reply to
    Seems like the time to get even...
    I have an original SM on paper but not scanned (yet). Now that's the perfect time to start with...
       Gunther
    Thanks for the laser tip. Still very far from getting a BC9500 as they are either expensive or mechanically spoiled Sad
  • 09-05-2011 11:56 AM In reply to
    Plenty of scrappers around to nick a laser from.
  • 09-05-2011 3:44 PM In reply to
    • yachadm
    • Jerusalem, Israel
    • Posts 687
    I've got a nice pile of scrap CDM2 lasers, which I thought I could warehouse for when needed in BG5500's, BC8500's, BC9500's etc. No luck. There are more dead scrap lasers than good scrap lasers out there. Unfortunately.
    Tread carefully before parting with your hard-earned cash on used CDM2's - there's no guarantee that the lasers are good.
