Hello there, FYI,
Beovision 1 sits on the video stand on a small pole that is screwed to the video stand.
You need to allign the rear of the set so that it is facing straight, and the small hole on the rear of the pole is alligned with the hole on the rear of the set. (At the rear of the tv and at the base were the tv set goes to a point).
The set is attached via a small allen key fitment screw, simple loosen the screw and the set will become loose, then simply lift the set off (this could take two people!!).
Hope this helps and isnt too confusing!!
Bang & Olufsen of King Street - Manchester,UK. SKYPE - beokingstreet
