new2brian: insert/edit image doesn't show my photos on forum
Insert/Edit Image is the photo icon on the line of other icons such as Font and Bullets when you create a post
It requires you to store somewhere on the Internet your image and provide an HTTP link (image URL)
Some people store their images under their profile on this site, others use a service like Image Shack
A quicker way is to go to the tabs at the top of the post
Move from "Compose" to "Option" and select "Add/Update" File Attachment
This will let you upload an image directly from your Pc
So it is a faster workflow
But ... (there is always a but) ... it only adds one photo per post
So try it and see if you can get at least one picture to load
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
