Latest post 08-23-2011 6:28 PM by beojeff. 6 replies.
Page 1 of 1 (7 items)
  • 08-16-2011 10:10 AM
    Encore - Time Capsule
    Dear all,
    I have serched the WEB quite a lot, but nowhere found a easy to understand information of how I could use my Time Capsule as DLNA device for future running a BS5 encore with having my music files on the time capsule. Right now I have an iMac with all data and beoport together with my BS3200. But I want to come to a point where the iMac does not need to run around the clock anymore.
    I know that time capsule cannot DLNA, but there are some programs out there that enable it to do so. I read about Twonkey but did not look through the description on the twonkey site..
    Thank you for your advices,
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 08-17-2011 7:34 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Re: Encore - Time Capsule
    Why searching to tweak the Time Capsule and not replacing it by a full featured NAS, which will do everything the TC does, and add DLNA compatibility?
  • 08-17-2011 5:12 PM In reply to
    • Style
    • Not Ranked
    • Joined on 08-01-2011
    • Posts 40
    TC is a backup solution and a router. It is not designed as a NAS. Get a cheap NAS and plug it in to the TC
  • 08-19-2011 4:57 AM In reply to
    Understand. But I have enough place on TC and would love to keep my "machine park" as it is.
    So is there no way to use the TC as DLNA server?
  • 08-22-2011 2:09 PM In reply to
    Sorry, no.
    As long as Apple does not provide such a service as part of the software i am afraid you have to go for a separate NAS.
  • 08-22-2011 2:12 PM In reply to
    Can't the Encore access music files from a standard shared hard drive? (Shared using SMB?)
  • 08-23-2011 6:28 PM In reply to
    A while back, I used my Time Capsule to stream content to a PS3. It required a program called MediaConnect. However, a problem with the Time Capsule was always getting it to "wake up." I wouldn't recommend using the Time Capsule for this purpose.
