Latest post 08-14-2011 6:37 AM by ReneB. 2 replies.
Page 1 of 1 (3 items)
  • 08-14-2011 4:49 AM
    • ReneB
    • Not Ranked
    • Joined on 04-22-2007
    • Posts 20
    • Silver Member
    Audio AUX Link functionality
    Hello,  I greatly benefit from my MX7000's "Audio AUX Link" 7-pin socket, which -connected to the AUX of my Beosound 2300- allows me to independly control the volume of both my Beolab 8000 (/w PL too MX7000) and my Beolab 3 (/w PL to 2300).
    Question: I'm considering a (second life) BeoVision flatter screen. Can I get with either the BeoVison 5, 9 or 7 series the same functionality of the Audio AUX Link socket of the MX7000 ?
    I looked at the manuals of all three and it seems to me that none of these can do this. Am I correct?? thanks, Rene
  • 08-14-2011 6:03 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Audio AUX Link functionality
    Yes. AUDIO AUX LINK functions will also work with BV 5, 6, 7, 8, 9, 10... and other Masterlink equipped Beovisions.
    You will need a Beolink converter 1611and a Masterlink cable. It converts Datalink (Audio Aux Link) to Masterlink.
    If you get a Beovision with an inbuilt surround decoder, I`d connect all speakers to the Beovision and set BS2300 to A.OPT 0 and BV? to V.OPT 2.
    In this mode your system will be controlled via the BV and you can get surround sound (DD , DTS).
    Stefan
  • 08-14-2011 6:37 AM In reply to
    • ReneB
    • Not Ranked
    • Posts 20
    • Silver Member
    THANKS for your clear answer and additional recommendation too!
    Just found a B&O dealer nearby that offers a 2004 Beovison 5 "in perfect state" for a very attractive price...(but have to check it can properly display digital TV signals...).
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
