Hi All,
I have my BeoVision 7-40 Mk II connected to Sky HD with DVI and co-ax audio as well as a SCART cable.  I have the IR sender to the Sky HD box, and use both my Beo4 and Beo5 remotes with this setup.
Everything works exactly as advertised, but when I type channel numbers in manually there's a pause of up to 30 seconds before the numbers are sent to the Sky HD box.  This problem is not evident when I use the original Sky+ remote.
I can use the Sky EPG, but this problem prevents me from using preset channel buttons on my Beo5, so I'd really like to get to the bottom of it!  I'd be very grateful for any suggestions.....
Thanks,
Simon.
