Latest post 08-07-2011 4:50 AM by kmumme. 8 replies.
Page 1 of 1 (9 items)
  • 08-05-2011 2:03 PM
    Various error photos of BS5
    Hi I'm new member of Beoworld!!!!
    Please take a look error pictures of BS5
    I tried several kinds connecting with non-B&O tv.
    Using DVI-hdmi cable, USB extention cable
    Now my BS 5 back to normal.
    I recommend that do not use after maket USB extention cable.
    But I'm still trying to connect non-B&O tv and BM5 using PHOTO and WEB menu through IR eye sensor.
    Can anyone knows about that?
    Thank you.
    Jack.
  • 08-05-2011 4:00 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Various error photos of BS5
    You connected your BS5 to TV DVI output. Have a look into the manual.
    Stefan
  • 08-05-2011 4:38 PM In reply to
    Thank you for reply Stefan.
    I didn't connect DVI out put of BM5.(I know manual very well). Also It didn't work. Just show up. Also I didn't touch any button. beo4 too.
    That picture show up around 30 seconds nothing work and than disappear.
    Jack.
  • 08-05-2011 5:00 PM In reply to
    • stefan
    • Posts 1,733
    Sorry. What we can See on your BS5 screen is exactly what your Beovision should display - but in wrong format.
    I know there is no BV in your setup.... BM5 has two DVI outputs, just try the other one...
    Stefan
  • 08-06-2011 5:03 AM In reply to
    Jack,
    What you can try is reset the beoSound 5 to factory defaults (compleet reboot) it won't affect youre music.
    In some cases the BeoSound 5 has a sort off memory for the display ports and send out the wrong video channel to the wrong video port.
    when you did the reset first connect the beosound 5 without the usb extension
  • 08-06-2011 10:23 AM In reply to
    jack001:
    Jack.
    could you give us a detailed (really detailed) information how you connected the BS5 & BM5?
    Did you install software on the BM5 (external desktop connection f.e.)? If yes, please which software is installed?
  • 08-06-2011 1:11 PM In reply to
    Thank you for your reply Carpola!
    Pop up window(last picture) show up when I tried BM5 and non B&O tv by DVI-HDMI cable. It was disappear use by DVI-RGB cable.
    Other pictures was show up
    1. Use after market USB extention cable(other BS5 cables use original 9meters) : Any reaction except blinking led light (over an hour)
    2. After disconnect all the BS5 cables and reconnet 4.5meters original cables: It show up first and second pictures for 30 seconds and disappear.(after that led light blinking over an hour with small cursor appear left side of BS5.)
    Also I connected IR eye sensor.
    3. Finally I bought original USB extension cable(4.5meters) and reconnect with original 9 meters cables than back to normal.
    However I am still do not know how can I use photo and web menu through the IR eye sensor (there are no reaction) with non B&O tv.
    My B&O system BS9000 & BM5/BS5 joined by ML. My BS5 use slave of BS9000.(No audio master)
    Jack.
  • 08-06-2011 3:04 PM In reply to
    Hi Jack,
    reconsidering I do not think your wished setup with a non B&o tv would work. The istallation guide doesn't say anything about a non B&o tv-set (there are even restrictions to older B&o tv's)
    The problem will be the instructions/commands for the BM5 to start WEB and/or Photo to your non B&o tv and at the same time work correctly with N.Music & N.Radio on the BS5.
    If you choose to solemnly use the BM5 then it would I think be possible to use all features. But than you are stuck with a unused BS5 unit!
  • 08-07-2011 4:50 AM In reply to
    Hi Jack,
    I'm trying since month, to use the web and Photo's on a non B&O TV. It doesn't work!!!
    For me, it is no problem to get the main screen on my Pioneer plasma, but the IR-Sensor on the BM5 still doesn't work. So you can't choose the web and photo menu items on the screen. I'm waiting since I bought the BS5 in January 2009 for this feature but I think, B&O did not realize it anymore.
    Kai
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
