Latest post 08-02-2011 10:50 AM by sergi0. 4 replies.
Page 1 of 1 (5 items)
  • 08-01-2011 6:14 PM
    beocenter 2 and socket
    Hi folks!
    Another question from a newby... I may have the opportunity to buy a beocenter 2 unit and the socket unit separately. Will the 2 combined worked? I do not see why it won't BUT I might suspect the use of a form of "bond" between the two...
    Of course, the purchase is legal, it is from a trusted seller. I already told him that I may contact B&O regardless the serial number.
    cheers,
    sergio
  • 08-01-2011 11:29 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    Re: beocenter 2 and socket
    Yes they'll work together.  Make sure the seller of the socket unit provides the PIN code.  You'll also need the connection cable.  And some of these just play CD's, not DVD's.  Make sure you know what you're getting.
  • 08-02-2011 5:59 AM In reply to
    • frog
    • Top 500 Contributor
    • Posts 191
    Be careful. The DAB-socket may not work with a non-DAB head.
    See the writeup in the main product sections:
    "Note: To have the DAB module fitted to your BeoCenter 2 is essential that both the Socket Unit and Master unit are the latest versions. Mixing existing stock of Master Units (pre-serial number 18139286) and DAB Socket Units (part number 1280020) is not possible."
  • 08-02-2011 8:06 AM In reply to
    • Opman
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    There are two versions of BeoCenter2, mark1 and mark2.
    The socket box and head unit MUST be of the same version. It is NOT possible to connect a mark1 and a mark2 together. If you can post the four digit type number for each product, it is possible to tell whether you are planning to buy a matched pair.
    Regards
    Opman
  • 08-02-2011 10:50 AM In reply to
    Thanks for the tips!
    I just read here (http://beocentral.com/beocenter2) that there are 2 differents finition : Aluminium and Steel. What are the differences? I was not able to find pictures of them on Internet. Maybe somebody have it here ;)
    thanks in advance,
    sergio
