Latest post 08-01-2011 4:38 PM by andyt1979. 3 replies.
Page 1 of 1 (4 items)
  • 08-01-2011 3:10 AM
    N Music Role Change
    After recently recovering my Beomaster 5/Beosound 5 back to day one settings I am having an issue where it wont allow me to change the role setting from N Music to CD - allowing me to control the system quickly with a Beo4 remote. When I select CD the system always reverts back to N Music. It will however allow me to change the role of N Radio to Radio. Has anyone else encountered this problem and know a solution?
  • 08-01-2011 12:38 PM In reply to
    Re: N Music Role Change
    what is your sw version after the recovery?
    maybe you should do an update.
  • 08-01-2011 12:41 PM In reply to
    • Rolf
    • Not Ranked
    • Joined on 04-21-2007
    • Stockholm, Sweden
    • Posts 63
    I would suggest to turn OFF and On the AudioMaster setting. With the AM option set to OFF the BM5/BS5 should not accept the CD/RADIO setting any longer and this might clear up the internal database.
    Good Luck
    //Rolf
  • 08-01-2011 4:38 PM In reply to
    No joy [:'(]
