Latest post 08-01-2011 6:58 AM by Step1. 5 replies.
Page 1 of 1 (6 items)
  • 07-30-2011 8:41 PM
    Left channel out on MMC20EN
    Has anyone SUCCESSFULLY dismantled and repaired a B&O MMC 20 series cartridge?  I just got a MMC20EN that is out in the left channel.  There is no continuity between the left channel contacts.  The cartridge itself is in stunning condition.  It looks almost new, and I can only assume that it failed very early in its life.  Has anyone successfully performed surgery on this series of cartridges?
    Kevin
  • 07-31-2011 2:00 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Left channel out on MMC20EN
    Very difficult because of the way the whole thing is cast into its housing.
    Axel in Germany, Soundsmith in the US and a few others can repair and replace
    the cantilever suspension but they seem to open the front end only.
    I never saw a (succesful) opening of the socket end. Certainly, both of the above
    mentioned reject repairs to cartridges with broken electrics.
  • 07-31-2011 3:50 AM In reply to
    I know Tim has pulled apart a number of cartridges in an attempt to fix them. I think he has managed but the attrition rate was too high to make this anything but an exercise in seeing it it was possible. I would suggest a new cartridge is the best way forward. Remember any working cartridge can be uprated to the highest spec. I have a MMC20S which has been fitted with a shibata diamond and tapered cantilever.
  • 07-31-2011 5:08 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-10-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Normal 0 false false false EN-US X-NONE X-NONE /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
    Probably not the same problem, but I thought I'd share a recent experience anyway.
    I purchased a new Soundsmith cartridge that arrived and did not work in my BG3404 (I purchased it for a BG4002, but that's another story).  There was no output in the right channel.  Figuring the chances of a brand new cartridge arriving DOA small, I suspected the new cartridge just wasn't making contact in the tonearm.  I have a working MC3000 and working MMC20EN, so I new the table, cables, receiver input, etc., were all fine.
    I contacted Soundsmith and ended up talking to the owner by telephone.  After sending the cartridge back, I received this email after only 48 hours:
    Dear Mr. Haffner; I have received and tested the SMMC20EN; the cartridge itself is fine, however, the connector might have been too loose for your particular tone arm contacts. I have made it tighter, and feel that this should connect more securely to your tone arm contacts.  The original B&O cartridges had more tolerance for variations in contact pressure than my design, and I have seen this problem once before. I feel certain that the modifications I have done will now work well - It will ship out on Monday - best regards - Peter Ledermann
    Perhaps your cartridge isn't making contact in the tonearm?  Have you another table to test it in?
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 07-31-2011 5:47 PM In reply to
    Rich:
    I tried it in two different decks, without success.  I cannot get continuity across the left channel contacts, so I'm pretty sure the cartridge is at fault.  Thanks, evryone, for the feedback and advice.
    Kevin
  • 08-01-2011 6:58 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    I remember the cartridge on my mums old 4000 fell out of its housing!! I seem to remember a green plastic frame with the coils inside it. I should imagine it hadn't had sufficient glue in the fatory for it to do that though!!! I think the metal back comes off quite easily but the rest is quite fast!
    I wander if the cantalever could be rescued by the likes of Axel?
    Olly.
