Normal
0
false
false
false
EN-US
X-NONE
X-NONE
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-qformat:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:11.0pt;
font-family:"Calibri","sans-serif";
mso-ascii-font-family:Calibri;
mso-ascii-theme-font:minor-latin;
mso-fareast-font-family:"Times New Roman";
mso-fareast-theme-font:minor-fareast;
mso-hansi-font-family:Calibri;
mso-hansi-theme-font:minor-latin;
mso-bidi-font-family:"Times New Roman";
mso-bidi-theme-font:minor-bidi;}
Probably not the same problem, but I thought I'd share a recent experience anyway.
I purchased a new Soundsmith cartridge that arrived and did not work in my BG3404 (I purchased it for a BG4002, but that's another story). There was no output in the right channel. Figuring the chances of a brand new cartridge arriving DOA small, I suspected the new cartridge just wasn't making contact in the tonearm. I have a working MC3000 and working MMC20EN, so I new the table, cables, receiver input, etc., were all fine.
I contacted Soundsmith and ended up talking to the owner by telephone. After sending the cartridge back, I received this email after only 48 hours:
Dear Mr. Haffner; I have received and tested the
SMMC20EN; the cartridge itself is fine, however, the connector might have been
too loose for your particular tone arm contacts. I have made it tighter, and
feel that this should connect more securely to your tone arm contacts. The original B&O cartridges had more
tolerance for variations in contact pressure than my design, and I have seen
this problem once before. I feel certain that the modifications I have done
will now work well - It will ship out on Monday - best regards - Peter
Ledermann
Perhaps your cartridge isn't making contact in the tonearm? Have you another table to test it in?
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
