        1st March February 2012
	    Latest post 08-30-2011 10:16 AM by  Leslie. 30 replies.
								        07-28-2011 9:32 AM
									        Søren Mexico
								                - Joined on 09-13-2007
								                - Mexico city
								                - Posts 1,621
										    Der Laie staunt, und der Fachman wundert sich, google cant translate that correctly, but I'm sure you get it, amazing work Leslie
									    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
									        Kokomo
								                - Joined on 08-21-2007
								                - Spain
								                - Posts 618
Well done again Leslie. Thanks for the photos as it's always great to see what some people such as yourself can achieve.
Please tell me though, what is the 'black stuff' you have used underneath the glass panel visible in the first two photos? I presume it's out of one of the small paint pots shown? If so what exactly is the stuff?
Thanks and well done again.
									        h1npw
								                - Joined on 04-16-2007
								                - A cricket ball throw from         Trent Bridge
								                - Posts 776
										    That looks like a real labour of love! Must have taken you many hours....but.... the results are fantastic!
Cheers
Nigel
									        Leslie
								                - Joined on 05-07-2009
								                - Netherlands
								                - Posts 2,201
										    Lots of questions and positive remarks, thanks guys, makes me feel proud of what I'm doing.
I bought 10 blanc glaspanels cut in Beomasters specific size and they have been poly sanded (not sure if you call it that way in english). About 5 euro each (plain cut, not poly sanded).
One side has been sprayed with black laquer (rear side)
Laser engraved text in mirror on the rear side. Laser engraving on glas makes the engraving white. Brought these panels at Adelfi. Excellent workman ship done by these two brothers. Cost me 10 euro each.
Bought this stuff on Ebay which is called Carbon conducting paint. Great stuff and best practice is to use a brush. Paint this carbon on places where the touch areas takes place (on top of the black laquer). The upper row text must be covered with tape or better use stickers. I had them in the size of the text. Make it a lot easier since you dont wanna cut in the paint.
For coloring text use glas paint. White for the lower row and red and green for the upper row.
I still have to do 9, so will try to make a sort of workinstruction for those who are interested. As said many times before, pictures says more then al lot of bla bla bla!
									    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
									        Leslie
								                - Netherlands
								                - Posts 2,201
										      Step1:
Very nice Leslie, you just need to improve contrast how above spraying the display windows with automotive stuff used to darken stoplights etc...
BTW how did you produce the illuminated text the best I came up with was to print onto ohp stuff but yours looks very professional!
Olly, that's a good idea. What kind of stuff is this "automotive" thing. Have you got a link?
The text has been laser engraved in mirror on the back. After that I used glass paint for emphasizing the text.
									        Paul
								                - Joined on 10-07-2010
								                - The Netherlands
								                - Posts 103
									        Leslie
								                - Netherlands
								                - Posts 2,201
										      h1npw:
Cheers
Nigel
Nigel, now I know how the proces works, it's a piece of cake, really!
									        Leslie
								                - Netherlands
								                - Posts 2,201
										      Evan:
Leslie! Those look amazing!! Another fine result sir!
Not to mention the red lid!
Your work is impeccable Leslie! It all looks good to me!
We can all learn from each other Evan
									        Leslie
								                - Netherlands
								                - Posts 2,201
										      Evan:
									        Leslie
								                - Netherlands
								                - Posts 2,201
										      Kokomo:
Answer has been given Kokomo, thanks! It's the black bottle (carbon conductive paint)!
									        Leslie
								                - Netherlands
								                - Posts 2,201
										    Olly, you think I should take the red one?
									        Leslie
								                - Netherlands
								                - Posts 2,201
										    Thanks Henrik,
You confirmed what someone else told me to do, and thats the Frutiger font.
Where can I get that and how on earth did you knew it is Arial
Next panels (name it) will be done in Frutiger if I can get it! Thanks for the tip...
Leslie
									        henrik
								                - Stockholm, Sweden
								                - Posts 299
										      Leslie:Where can I get that and how on earth did you knew it is Arial
Hehe! Well, I'm a typography geek! :) When it comes to Arial vs Helvetica, the "R" ang the "G" is the most obvious difference. Unfortunately, Frutiger is not a free font so you'll have to but it unless someone is kind enough to lend it to you ;) I'm at the summerhouse at present and do not have access to my font collection.
Older B&O equipment (all 70's stuff and most of the 80's gear) used Helvetica, newer uses B&O's own variant of Frutiger.
									        egoh
								                - Joined on 04-12-2011
								                - Austin, Texas - USA
								                - Posts 77
										    Leslie,
Amazing, amazing work. Well done. I was wondering when someone would have the guys and skills to try this. Beautiful job!
									        Søren Mexico
								                - Mexico city
								                - Posts 1,621
										      henrik:Where can I get that and how on earth did you knew it is Arial
Here
									        Leslie
								                - Netherlands
								                - Posts 2,201
										    Thank you Søren for the link and Eric, it's not really a challenge, more fun to do and maybe others can do something with it! Soon I will post some pictures for the "workinstruction"!
									        Søren Mexico
								                - Mexico city
								                - Posts 1,621
										    A freind of mine in France needs a panel for BG CD 4500 (if Martin cant deliver), can you make one ??
