Latest post 08-30-2011 10:16 AM by Leslie. 30 replies.
Page 1 of 2 (31 items) 1 2 Next >
  • 07-28-2011 9:32 AM
    I did it!
    Finally after weeks of "research"Smile I made my own glaspanel with all in working functionality (touch sensitivity and text).
    Check my proto on the Beomaster 3500.
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 07-28-2011 10:26 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: I did it!
    Leslie! Those look amazing!! Another fine result sir!
    Not to mention the red lid!
    Your work is impeccable Leslie! It all looks good to me! WinkYes -  thumbs up
    Evan
    Re: I did it!
    Der Laie staunt, und der Fachman wundert sich, google cant translate that correctly, but I'm sure you get it, amazing work LeslieYes -  thumbs upHmm
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 07-28-2011 10:58 AM In reply to
    • Step1
    • Top 75 Contributor
    • Joined on 07-06-2008
    • Manchester
    • Posts 961
    • Gold Member
    Re: I did it!
    Very nice Leslie, you just need to improve contrast how above spraying the display windows with automotive stuff used to darken stoplights etc...
    BTW how did you produce the illuminated text the best I came up with was to print onto ohp stuff but yours looks very professional!
    Olly.
  • 07-28-2011 11:26 AM In reply to
    • Kokomo
    • Top 100 Contributor
    • Joined on 08-21-2007
    • Spain
    • Posts 618
    Re: I did it!
    Well done again Leslie. Thanks for the photos as it's always great to see what some people such as yourself can achieve.
    Please tell me though, what is the 'black stuff' you have used underneath the glass panel visible in the first two photos? I presume it's out of one of the small paint pots shown? If so what exactly is the stuff?
    Thanks and well done again.
  • 07-28-2011 1:19 PM In reply to
    Re: I did it!
    Nice work, looks good in red!
  • 07-28-2011 2:18 PM In reply to
    • h1npw
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Re: I did it!
    That looks like a real labour of love! Must have taken you many hours....but.... the results are fantastic!
    Cheers
    Nigel
  • 07-28-2011 3:48 PM In reply to
    • Paul
    • Top 500 Contributor
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    Re: I did it!
    Great job Leslie!!! That looks amazing!  Well done!   The quality of the [panel on the pictures look very real and original. I am convinced you can replicate every glasspanel, lets say a BC9500.  I wonder how long it took to produce one panel.  It looks cool to make an Ipod version instead of a Tape2 on the panel
    You keep amaze me everytime, your skill, devotion and dedication to restore every piece of B&O you lay your hands on.  Yes -  thumbs up  Well done mate!!
  • 07-28-2011 3:49 PM In reply to
    Re: I did it!
    Lots of questions and positive remarks, thanks guys, makes me feel proud of what I'm doing.
    I bought 10 blanc glaspanels cut in Beomasters specific size and they have been poly sanded (not sure if you call it that way in english). About 5 euro each (plain cut, not poly sanded).
    One side has been sprayed with black laquer (rear side)
    Laser engraved text in mirror on the rear side. Laser engraving on glas makes the engraving white. Brought these panels at Adelfi. Excellent workman ship done by these two brothers. Cost me 10 euro each.
    Bought this stuff on Ebay which is called Carbon conducting paint. Great stuff and best practice is to use a brush. Paint this carbon on places where the touch areas takes place (on top of the black laquer). The upper row text must be covered with tape or better use stickers. I had them in the size of the text. Make it a lot easier since you dont wanna cut in the paint.
    For coloring text use glas paint. White for the lower row and red and green for the upper row.
    I still have to do 9, so will try to make a sort of workinstruction for those who are interested. As said many times before, pictures says more then al lot of bla bla bla!
  • 07-28-2011 3:52 PM In reply to
    Re: I did it!
    Step1:
    Olly, that's a good idea. What kind of stuff is this "automotive" thing. Have you got a link?
    The text has been laser engraved in mirror on the back. After that I used glass paint for emphasizing the text.
  • 07-28-2011 3:57 PM In reply to
    • Paul
    • The Netherlands
    • Posts 103
    • Gold Member
    Re: I did it!
  • 07-28-2011 4:02 PM In reply to
    Re: I did it!
    Dank je Paul!
  • 07-28-2011 4:04 PM In reply to
    Re: I did it!
    h1npw:
    Cheers
    Nigel
    Nigel, now I know how the proces works, it's a piece of cake, really!
  • 07-28-2011 4:09 PM In reply to
    Re: I did it!
    Evan:
    We can all learn from each other EvanWhistle
    Re: I did it!
    Evan:
  • 07-28-2011 4:13 PM In reply to
    Re: I did it!
    Kokomo:
    Answer has been given Kokomo, thanks! It's the black bottle (carbon conductive paint)!
  • 07-28-2011 4:33 PM In reply to
    • Step1
    • Manchester
    • Posts 961
    • Gold Member
    Re: I did it!
    http://shop.ebay.co.uk/i.html?_nkw=REAR+LIGHT+TINT+SPRAY&_sacat=0&_dmpt=UK_CarsParts_Vehicles_CarParts_SM&_odkw=rear+light+spray&_osacat=0&_trksid=p3286.c0.m270.l1313
    search for REAR LIGHT TINT SPRAY I hope it is suitable!
    Olly.
  • 07-28-2011 4:47 PM In reply to
    Re: I did it!
    Olly, you think I should take the red one?
  • 07-29-2011 4:35 AM In reply to
    • henrik
    • Top 200 Contributor
    • Stockholm, Sweden
    • Posts 299
    Re: I did it!
    Amazing! Really impressive! Great work, I only have one minor gripe: you should use Helvetica or Frutiger instead of Arial! :-) ...but apart from that, great work!
  • 07-29-2011 5:44 AM In reply to
    Re: I did it!
    Thanks Henrik,
    You confirmed what someone else told me to do, and thats the Frutiger font.Left Hug
    Where can I get that and how on earth did you knew it is ArialYes -  thumbs up
    Next panels (name it) will be done in Frutiger if I can get it! Thanks for the tip...
    Leslie
  • 07-29-2011 6:53 AM In reply to
    • henrik
    • Stockholm, Sweden
    • Posts 299
    Re: I did it!
    Leslie:
    Hehe! Well, I'm a typography geek! :) When it comes to Arial vs Helvetica, the "R" ang the "G" is the most obvious difference. Unfortunately, Frutiger is not a free font so you'll have to but it unless someone is kind enough to lend it to you ;) I'm at the summerhouse at present and do not have access to my font collection.
    Older B&O equipment (all 70's stuff and most of the 80's gear) used Helvetica, newer uses B&O's own variant of Frutiger.
  • 07-29-2011 8:30 AM In reply to
    • egoh
    • Not Ranked
    • Joined on 04-12-2011
    • Austin, Texas - USA
    • Posts 77
    • Gold Member
    Re: I did it!
    Leslie,
    Amazing, amazing work. Well done. I was wondering when someone would have the guys and skills to try this. Beautiful job!
  • 08-01-2011 10:36 AM In reply to
    Re: I did it!
    henrik:
    Here
  • 08-01-2011 4:13 PM In reply to
    Re: I did it!
    Thank you Søren for the link and Eric, it's not really a challenge, more fun to do and maybe others can do something with it! Soon I will post some pictures for the "workinstruction"!
  • 08-01-2011 4:20 PM In reply to
    Re: I did it!
    A freind of mine in France needs a panel for BG CD 4500 (if Martin cant deliver), can you make one ??
