Hi everyone and thanks for being so helpful all the time :)
I know this might be a very broad question but I don't really know these things very well.
I have a pair of older Beolab 8000 that I need to hook up to a receiver but I really don't know what to get. I don't care much for 5.1 sound or a lot of features, I just need something that works well with stereo. Most likely I will use them to play music through my computer and perhaps connect a media player to it.
Audio quality of obviously the most important thing. How would I go on about that? Should I get a receiver with optical input (to connect my computer) that has a good AD/DA converter inside of it, or should I do it some other way.
I know there's a ton of receivers out there but any advice are appreciated. What are you running on?
And oh, I'm on a pretty tight budget.
Thanks!
Felix
