Latest post 07-29-2011 11:03 AM by Felle. 10 replies.
Page 1 of 1 (11 items)
  • 07-26-2011 7:36 PM
    • Felle
    • Not Ranked
    • Joined on 07-23-2007
    • Posts 36
    Receiver to use with BL8000
    Hi everyone and thanks for being so helpful all the time :)
    I know this might be a very broad question but I don't really know these things very well.
    I have a pair of older Beolab 8000 that I need to hook up to a receiver but I really don't know what to get. I don't care much for 5.1 sound or a lot of features, I just need something that works well with stereo. Most likely I will use them to play music through my computer and perhaps connect a media player to it.
    Audio quality of obviously the most important thing. How would I go on about that? Should I get a receiver with optical input (to connect my computer) that has a good AD/DA converter inside of it, or should I do it some other way.
    I know there's a ton of receivers out there but any advice are appreciated. What are you running on?
    And oh, I'm on a pretty tight budget.
    Thanks!
    Felix
  • 07-26-2011 7:38 PM In reply to
    • Felle
    • Not Ranked
    • Posts 36
    Re: Receiver to use with BL8000
    I don't mind going with an older but high quality receiver but obviously I would have to get an external AD/DA converter with that to get good sound through my computer. What is a good solution?
  • 07-26-2011 11:57 PM In reply to
    beoport pc
  • 07-27-2011 1:07 AM In reply to
    Just use the line in on the Beolabs... no need for an amp or a receiver
    My B&O: 2009 Catalogue and Pricelist
  • 07-27-2011 2:27 AM In reply to
    As the BL8000 are active speakers you do not need a Receiver. Just buy a decent DAC. You might also check our pro-ject Audio Boxes. They make very nice and small Audio equipment.
    Connecting the BL8000 directly to your Computer is just a good idea if you do not plug/unplug the connection too often (gives a cracking sound each time).
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 07-27-2011 4:05 AM In reply to
    • Felle
    • Not Ranked
    • Posts 36
    Connecting my computer directly is NOT a good idea. I will either use an older iMac for my system which has a pretty noisy and bad output. Or I will use my newer Macbook Pro laptop which has a better output but means I will have to to unplug it all the time.
    I should probably get a good DAC. What should I get?
    I would probably need something with a volume controller, right?
  • 07-27-2011 5:54 AM In reply to
    • Felle
    • Not Ranked
    • Posts 36
    I found this neat little thing: http://www.nuforce.com/hp/products/iconhdp/index.php
    Will this work well if I plug in my BL8000 to the headphone output?
  • 07-27-2011 12:41 PM In reply to
    Headphone Output is no good idea as this has wrong line level. Take any DAC and control volume level via the MB Pro or use an Apple remote with you MB Pro - should also work.
  • 07-27-2011 12:59 PM In reply to
    • Felle
    • Not Ranked
    • Posts 36
    Heribert:
    I don't think I can control the volume from my computer if I'm outputting digital signals through an optical cable.
  • 07-27-2011 6:49 PM In reply to
    I did this: Bought a cheap E-machines, upgraded with a good sound card and ran my BL 8000 directly from the line out.
    Later I bought an Onkyo amp/reciever, connected the comp. with optical cable, connected the 8000s to the amp. and yes I can use the volume control on the comp. and the reciever.
    I use my amp. for sound from TV, blu-ray, dvd, Set top box and turntable, do not buy a cheap amp. buy one with a lot of inputs and outputs, this will make you more flexible, when you add new or more devises.
    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
  • 07-29-2011 11:03 AM In reply to
    • Felle
    • Not Ranked
    • Posts 36
    I realized I actually have a decent soundcard I can use, hadn't thought of that.
    Focusrite Sapphire LE.
    Should be good enough!
    Thanks for all the advice
