Latest post 07-29-2011 1:20 PM by Stan. 13 replies.
Page 1 of 1 (14 items)
  • 07-26-2011 2:16 PM
    BeoMaster 5 / BeoSound 5 won't software upgrade!
    Hello everyone,
    My BeoMaster 5 / BeoSound 5 won't execute the manually software upgrade...
    When I press "Upgrade software" it shows the screen with the message "0 % downloaded".... and then nothing happens - even if I leave the BM5/BS5 alone in a couple of hours or even over night...
    The upgrade I wish to get is the one that enables me playing music from my iPhone on the BS5..
    Please help out a BS5/BM5-user (I have had the product in a couple of years now)....
    0 % download :(
    Cheers,
  • 07-26-2011 2:49 PM In reply to
    Re: BeoMaster 5 / BeoSound 5 won't software upgrade!
    maybe a reset would help you out?! Sometimes software does not respond in the way is was expected; often the "best" try is to shut down the whole thing and let it restart - sorry but I don't have any other idea (cause as you wrote that the system had enough time...
    regards elmar
  • 07-26-2011 3:34 PM In reply to
    Well - I have restarted the system several times now. So yeah - have tried that :) but thx for the respond!
  • 07-26-2011 3:58 PM In reply to
    Had a quick dig round known faults - one is the disc is full. What software are you running at present?
  • 07-26-2011 4:39 PM In reply to
    Hi Peter, thank you for participating in helping me solve this issue!
    Current BM5/BS5 application version is: 6.02.00.1902
    Current BS5 main firmware is: 1.33a
    Current BS5 boot firmware is: 0.04a
    FYI: The disc is far far far from full !...
    Btw: Manually software upgrade just responded "Failed"
    Hope this helps! Thank you very much again for participating - hope we can find a solution for me! :(
  • 07-26-2011 6:13 PM In reply to
    Had a look at the info I have and all it states is that there are errors in the software that they are working on! And the work around is to download the new software!!!! I think this is one for Keith or a dealer!
  • 07-27-2011 3:01 AM In reply to
    Thank you - but who is Keith? :)
  • 07-27-2011 7:13 AM In reply to
    BeoWorldMan:
    Keith Saunders is the webmeister of this site => http://forum.beoworld.org/members/Keith_5F00_Saunders/default.aspx
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 07-27-2011 5:16 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    How reliable is your connection to the internet?  If this is not reliable, then this too could cause issues upgrading the software.
  • 07-27-2011 5:19 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    If your network is reliable, you might also try restoring your system to a previous version (go into the extended menu <<, >>, <<, >>, GO) and find system restore.  This will take a while.  When this finishes, try the software upgrade again.
    These steps fixed mine (and a few others on the forum) when B&O mistakenly released some software before it had been completely cooked.
    Stan
  • 07-28-2011 3:41 AM In reply to
    Thank you for participating in this thread!
    First of all - my internet connection is very solid, 50 mb cabel connection.
    Secondly, I have now tried the reset functionality (this jumps the BS5/BM5 software back to 4.xx.xx.xxxx version) - and now .... when I try to manually update it - it does the same! - Stalls at 0 % downloaded ....arrrg!
    I tried to use N.radio - no problem at all
    I looked a the network info - the audio-product receives a network IP and everything is OK from that perspective...hmm!?
  • 07-28-2011 3:44 AM In reply to
    Wait ...! The update have begun!... Lets see if it can continue all the way to the most current version!
    Update on this topic TBA later!
  • 07-28-2011 4:02 AM In reply to
    The problem is SOLVED!
    Thank you all very much - specially Stan!
  • 07-29-2011 1:20 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    Big SmileBig SmileBig Smile
