1st March February 2012
Latest post 08-24-2011 8:27 PM by Evan. 85 replies.
Leslie
- Joined on 05-07-2009
- Netherlands
- Posts 2,201
Evan, you surprise me everytime, well done! Do they have the same size as the originals, they look a bit smaller? And this time in black? Keep up the good work man!
B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
Beovirus? What's that?
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Leslie:
Thank you, Leslie! The cube enclosure itself is actually the exact same size as the original, 95mm^3. I think the stand is what throws off the proportion, the base especially. They are several inches taller than the originals (due to the stands), but I will likely shorten them a bit more.
Yes, black - that must have been a bigger suprise! The reasons why; 1) The original color was black only. 2) they will be set on top of some speakers with black frets. Once they are placed I will give you more details on this - long story! A picture or two will help!
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Evan: Marked and drilled the holes, 1.5" hole saw.
More, MORE, More
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Evan
- Ohio | USA
- Posts 2,601
Søren Mexico:
More, MORE, More
I'm trying Søren! My internet keeps giving up right as I post a new pic...
Evan
- Ohio | USA
- Posts 2,601
At this point, all of the cube panels must be aligned. Also, all holes for brackets and tweeters must be made now in initial assembly as these are going to get a few coats of black paint.
I had to fabricate all of the brackets (16!) myself as even the smallest ready-made brackets from the hardware stores were too large. They were cut from the sides of aluminum square tubing. They are numbered once fitted to ensure they are put in the same place in final assembly.
Evan
- Ohio | USA
- Posts 2,601
This is a little out of order but I'll throw it in anyway. Tweeter size and installation is confirmed.
Just like I planned.
Rich
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
Evan:
You can see up at the top of the photo I have a glass of lemonade. It was helping me through some extremely hot weather - Rich & Soren!
Very nice work. Very inspirational project. I've been thinking of a speaker build myself - ambio speakers to complement my M70s in my BM4000 (the tower) system. I built a few pairs back in the late 80s and early 90s.
My beverages of choice would have been Maker's Mark on the rocks on the left, and a Mountain Dew Code Red chaser on the right! But I guess you care about sobriety while you work!
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Leslie
- Netherlands
- Posts 2,201
Evan, you should call them Babyvox 2500, a new b&o baby has born. Positiv critics though, hope you don't mind. The base you're using now makes the cubes smaller. Why not using the sime dims? Where did you buy the tweeter and has it the same size as the originals. Any specs of these on the net? Keep up posting Really enjoy your thread(s) with all the pictures.
Evan
- Ohio | USA
- Posts 2,601
Now for the biggest challenge, composing a stand.
I had brainstormed many thoughts on this, but settled on a ready-made table lamp base and it couldn't be any better. Being a lamp base, there is even a place for the speaker wire to travel through!
This particular base is also heavy enough to keep this suprisingly heavy tweeter stable.
Evan
- Ohio | USA
- Posts 2,601
Rich
- Posts 1,089
Evan:
What ever became of your CX50's? Those would be perfect for ambio.
Gave them to my mother-in-law.
