Hey guys,
Been troubling with this for a few days now and can't really get the hang of it. So I'll throw it out here and hope for someone to save my day. It's a problem regarding the Masterlink Gateway and how it will work with the Home automation / IHC Viewer Controller and the iPhone. The setup right now is that I've got:
- Masterlink Gateway
- LK IHC Viewer Controller
- iPhone
These 3 'devices' are all connected to the same network (Dlink router).
The situation is this: My Masterlink Gateway has been set up working with all my B&O devices (BeoVision, BeoLab, BeoSound etc) and is working nicely with the iPhone as a 'remote' over wireless. I would also like to be able to control the IHC in every room and therefore I've added the LK IHC Controller on the Masterlink Gateway configuration page. I've then put in the correct IP address and loaded the .VIS project onto here. I have also marked the input and output that I'd like.
From here I've went to 'Macros'. I'm not sure that I've done this part right (as it doesn't work), even though I find the choices I've made here fairly logical. In a created Macro I have done the following:
Events triggering this macro: Put in a virtual button with id: 1.
Commands executed by this macro: Put in a input for a touchfunction on light in the livingroom.
When I then connect to the Masterlink Gateway through the Beolink application on the iPhone, I will access the room where I've assigned the virtual button to. When I push this virtual button (which shall execute the input), it does nothing. Instead I get a error response on the configuration page of the Masterlink Gateway which says like this:
2011-07-23 20:57:32 notice server: BeoLinkDriver: BlCore: Accepting MLGW Protocol connections on TCP
2011-07-23 20:57:33 notice server: Initializing configuration
2011-07-23 20:57:33 notice server: IHC/LexControl: IHC: Connecting to URL <http://192.168.0.22/ws/OpenAPIService>2011-07-23 20:57:33 warn server: LkDriver: LkReceiveEvents: exception on Web Service method Wait for events: XML parse error
Anyone experienced this before? Would be very thankful if anyone has got an idea on how to fix this problem.
Thanks in advance,
Anders
