Latest post 09-06-2011 5:47 PM by dan1969. 51 replies.
Page 1 of 3 (52 items) 1 2 3 Next >
  • 07-23-2011 2:54 PM
    RL60 metal plate
    Today I have "reclothed" a pair of RL60's. When I opened the cabinet, a metal plate was loose inside the speaker cabinet.
    I wonder how this metal plae was attached to the cabinet. I can't find out how it was fixed???? The only way was straight on the cloth?
    Please help if you know how it was fixed. Thanks!
    B&O item 1, B&O item 2, B&O item 3,...................B&O item 735
    Beovirus? What's that?
  • 07-23-2011 3:02 PM In reply to
    Re: RL60 metal plate
    Search for "ABR"...
    (yes, foam rot.)
    -mika
  • 07-23-2011 3:03 PM In reply to
    Sorry guys, I think I know the answer myself. A sort of cardboard must have been used that was glued both to the metal plate and frame. But where is the cardboard? There was a lot of rubbish inside when I opened it. That could not be the cardboard was it?
  • 07-23-2011 3:05 PM In reply to
    Thanks Mika, have seen these threads (not thoroughly though) but I saw pictures where extra speakers has been added in this metal plate. Was that the purpose of this plate to cut holes for new drivers?
  • 07-23-2011 3:26 PM In reply to
    This is the result of my new reclothed RL60Smile
  • 07-23-2011 3:27 PM In reply to
    Leslie,
    never seen drivers in that plate. There are 2 versions of RL60:
    One had the ABR Mika mentioned. Looks like that's the one you have: The plate was the radiator and had a foam "ring" like a driver unit. Almost all of those are rotten nowadays.
    There was a fix with another plate a little bigger instead that had a sort of plastic tube glued onto and no more foam rings. It was screwed firmly into the frame.
    The debris inside of your RL's are the remainders of the foam. It is very hard as the softener disappeared with time. I had a lot of it in my RL60's although they have already been retrofitted with the bigger tube-plates before I got them.
    There is a thread somewhere with nice pictures where I learned this beside looking into my RL60s. Had to search toughly to find it. Maybe someone has a pointer and remembers...
       Gunther
    EDIT: found a picture of my non-ABR version:
    BTW: The red cloth matches the "redlines" much better than some fabric-selector-retrofitted M70's Stick out tongue
  • 07-23-2011 3:52 PM In reply to
    Here are two approaches:
    http://forum.beoworld.org/forums/t/25024.aspx
    http://forum.beoworld.org/forums/t/26823.aspx
    Never tried either myself. There was also a third one on an external site which replaced the original ABR with two more conventional round passive radiators, but that site seems to have gone unfortunately.
    -mika
  • 07-23-2011 4:01 PM In reply to
    You guys are great, thank you very much, very helpfull!
  • 07-23-2011 4:04 PM In reply to
    By the way and don't laugh!!!!! The first speaker I have attched the metal plate straight to the speaker cloth with double side tape. Stuuuuuuupid!EmbarrassedEmbarrassed
    Now I have to try to remove the plate from the clothSuper Angry
  • 07-23-2011 4:06 PM In reply to
    hemenex:
    Haven't you noticed Gunther that I changed the RL into WLBig Smile
  • 07-23-2011 4:59 PM In reply to
    • Paul
    • Top 500 Contributor
    • Joined on 10-07-2010
    • The Netherlands
    • Posts 103
    • Gold Member
    Leslie, The red cloth looks realy royal on the RL's  BTW where did you get the transparent ribbon across the cloth?
  • 07-23-2011 5:26 PM In reply to
    Paul:
    One of the lucky ones via this thread
    I think he still sells it on Ebay UK. Not sure though...
    The red really looks classy, next one will be dark blue. The cloths have been bought in the US, almost similar as the original ones.
    Did a lot of CX50's and 100's. Now I have the feeling how to do the embossing the proper way on the RL's with these cloths.
    Next project, and I'm in the last stage now, are making glass touch panels for the Beomaster 4500 incl. printing and touch sensitivityBig Smile
  • 07-23-2011 5:50 PM In reply to
    • Paul
    • The Netherlands
    • Posts 103
    • Gold Member
    Thanks, they called straps Embarrassed i saw he sells them on his site for 15 GBP shipping included.   Yes, I will refoam the CX100 this week or so. I replace the cloth of the frets because some of them got holes at the corners. I will look for silvery cloth or black cloth with silver wires in it. I think it looks nice with the black cx's
  • 07-23-2011 6:04 PM In reply to
    hemenex:
    Gunther, does this "radiator" has a function in the speakersystem? What does it do? Thought it was ment for a later upgrading with new drivers.
  • 07-24-2011 1:39 AM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    It is a radiator that works in the very same way as the ones on the BL2 and BL3. They are basically just passive radiators that react to the change in pressure inside the cabinet, as a result they move more air oustside the cabinet transmitting more sound. They are used to increase the bass.
    Evan
  • 07-24-2011 2:14 AM In reply to
    Wow Evan, never knew that, so it has a purpose!
    ShEmbarrassedt man, now I glued this bloSuper Angrydy thing to the speaker clothIck!
    Thanks!
  • 07-24-2011 5:07 AM In reply to
    Any alternatives to put the plate back in place? What kind of material can be used, cardboard maybe?
  • 07-24-2011 5:57 AM In reply to
    Didn't you read the links at all? The plate corresponds to the cone of a driver. It needs to be able to move.
    -mika
  • 07-24-2011 7:04 AM In reply to
    Sorry Mika, you're right, bit of lazyness! Answer was there...
  • 07-25-2011 4:34 PM In reply to
    Finished! Used sort of leather cloth (shammy leather?).
    Sounds greatSmile Thanks all!
  • 07-25-2011 4:47 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Good job Leslie, those look fantastic!
    BTW, is that a white BM3000 I spy on that shelf there?! And maybe even a BG1200 above?!?!?!
    Evan
  • 07-25-2011 5:24 PM In reply to
    Thank you Evan. Yes they are... You have a eyes like a hawkSmile
    Btw, still working on the BM4500 glass panels. This week laser engraving on the panels....
  • 07-25-2011 5:50 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    A 3000-2 no less! Complete with preset cover too! WOW Leslie, that is my dream combo. Congrats to you sir Yes -  thumbs up
    Right now my 3000-2 is still on the bench, in pieces awaiting parts from online. My BeoMaster 3000-2 is rosewood, type 2402 and a 108Mhz version.
    Looking forward to seeing your results on the 4500 panel. I am sure it will turn out great.
    Evan
  • 07-25-2011 5:55 PM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    It looks like you are having a good time right now with the volume up high, loudness on and the bass+treble boosted!
    You hosting a party or something?! Wink
    Evan
  • 07-25-2011 6:04 PM In reply to
    Evan:
    That must be a rare version or not Evan?
    Will keep you informed about the panels, even if I fail Sad
