Latest post 07-31-2011 5:43 AM by chartz. 17 replies.
Page 1 of 1 (18 items)
  • 07-21-2011 4:57 PM
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Beogram CD 5500 no power [solved]
    Hello everyone,
    Well my B&O quest goes on, and I've just bought a non-functional Beogram CD 5500. I've now got the best ones, haven't I, CDX and CD 5500!
    I will report on their differences once I have fixed the 5500...
    Truth is, there is no power at all. What should I look into? I don't know this model at all, but I guess some of you have some valuable advice to share before I test or dismantle anything... I have already repaired Philips CD players, but this looks a bit different (output op-amps??).
    Thanks.
    Jacques
  • 07-21-2011 7:00 PM In reply to
    • egoh
    • Not Ranked
    • Joined on 04-12-2011
    • Austin, Texas - USA
    • Posts 77
    • Gold Member
    Re: Beogram CD 5500 no power
    If nothing works/lights up at all, check the power supply section first. Check the caps and voltage regulators on board 5 to get started. What have you checked out so far?
  • 07-22-2011 1:27 AM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    I once got a CD5500 with the same problem, no power. I opened it and immediately saw two big diodes on the board that had bad solderings, they had almost come off! Resoldered, and the thing worked like new.
    Bang & Olufsen - The art of controlling sound, picture and light
  • 07-22-2011 8:25 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Thanks, I'll keep in touch.
    What do you think of its sound quality then?
    Jacques
  • 07-22-2011 4:37 PM In reply to
    Also check the solderings of the connectors for the powersupply on the decoder-PCB and the powersupply-PCB. These can also be bad!
  • 07-28-2011 4:50 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Hello!
    It turns out TF1 is open circuit.
    Can this be taken out and cleaned or changed? Or installing a 160mA fuse maybe?
    Jacques
  • 07-28-2011 5:24 AM In reply to
    I believe it is a thermal fuse because there aren't any proper fuses on the secondary side (just some fusible resistors). First and foremost I would be interested in why it failed - at least check all rectifiers for shorts before powering up. There's a small chance of a failed transformer as well, I guess...
    Generally thermal fuses are one-shot so you'll need to replace it. It is probably fine to troubleshoot with a conventional fuse, but I would't put the deck in regular duty until a new thermal fuse is in place.
    -mika
  • 07-28-2011 5:38 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Yes it is a 130 degrees thermal fuse. Can it be easily extracted?
    I will definitely check on the first rectifier diodes and the following capacitor (my guess).
    I think the transformer is okay, but 130 degrees is a lot!
    The windings resistance look fine but you will never see the lower layers!
    Jacques
  • 07-28-2011 6:10 AM In reply to
    chartz:
    Wish I knew - never had this problem myself, so I haven't paid attention to where it is actually located. It has a separate part number in the service manual, so I think it is supposed to be replaceable... Sometimes they are just pushed into a recess in the transformer body.
    -mika
  • 07-28-2011 7:51 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Right then. I replaced the 240V strap with a fuse holder, shorted the thermo fuse and the Beogram lives again, producing music and being stable. BUT the tray doesn't work. The heating was due to a shorted cap (C3).
    Some progress...
    Jacques
  • 07-28-2011 9:18 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Busted!
    The 12V zener (D5) had given up the ghost. It is used to provide the LM324 (tray functions) +DC.
    The player now works perfectly!
    By the way, is it normal that the magnetic puck is never properly centered on the CDM?
    And isn't the CompactDisc logo supposed to light up?
    Jacques
  • 07-28-2011 10:09 AM In reply to
    Yes -  thumbs up
    The puck has wobbled more or less on all I've seen under the lid. It's final placement seems just random at every load.
    No, I've never seen that logo light up! Cool idea, but against B&O simplicity I think...
    -mika
  • 07-28-2011 10:55 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Now proudly showing off in the system's rack... The odd one out is?? Stick out tongue
    Oh, and by the way, it does sound GREAT!
    And NO the Beomaster 6000 is not, will never be for sale, no matter how you beg. Big Smile
    Jacques
  • 07-28-2011 3:04 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    By the way, is the "clack" noise normal when the tray opens (just after you press the button)?
    It's the mech hitting the bottom plate!
    Jacques
  • 07-28-2011 5:02 PM In reply to
    • Rich
    • Top 50 Contributor
    • Joined on 07-11-2010
    • Orlando, Florida, USA
    • Posts 1,089
    • Gold Member
    Which model Nak is that?
    What loudspeakers are you using?
    Current primary listening:  SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
  • 07-28-2011 5:18 PM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    It's a CR-4. The speakers are mint MC120-2 with original stands.
    Jacques
  • 07-29-2011 4:18 AM In reply to
    chartz:
    More or less in all I've seen, at least when closing. But, the tray travel has some rubber bumpers you can barely notice in the explosion diagram. You might not find a trace of them left now! I never bothered to think of replacements, though...
    EDIT: part# 9016. Dunno how much it contributes to the noise.
    -mika
  • 07-31-2011 5:43 AM In reply to
    • chartz
    • Burgundy
    • Posts 984
    • Gold Member
    Anyway, yet another cap problem! This one had become a resistor!
    It's amazing - I now have some experience in B&O - how those electrolytics cause the majority of failures! I now buy very cheap, and non-functional but the equipment HAS to be nice to look at!
    Jacques
