1st March February 2012
Latest post 09-13-2011 10:09 PM by Søren Mexico. 11 replies.
Rich
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.01.59.19/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 07-10-2010
- Orlando, Florida, USA
- Posts 1,089
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
Re: Help with Beogram 3400 dustcover
Boy, that sounds just like the trouble I had with my spare RX 2. Yes, it can be reassembled. Yes, it's a pain. Can you post pictures? There's a trick to lining up the parts on the RX 2 that isn't exactly intuitive. With a picture, I'd be able to tell if it's the same.
Current primary listening: SMMC20EN -> BG4002 -> BM4000 -> Beovox M70
Dillen
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.31/avatar.jpg)
![Top 10 Contributor Top 10 Contributor](/Themes/beotheme1/images/rankicons/rankTop10.gif)
- Joined on 02-14-2007
- Copenhagen / Denmark
- Posts 5,008
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Start at the center. Let the spring ends float free and concentrate on the holders. Finally lift the spring ends into their grooves in the lid. If you need one of these, PM me.
![](http://forum.beoworld.org/cfs-file.ashx/__key/CommunityServer.Components.UserFiles/00.00.00.21.31.Assistance/Holder.jpg)
hwystar
![](/utility/anonymous.gif)
![Not Ranked Not Ranked](/Themes/beotheme1/images/rankicons/rank0.gif)
- Joined on 07-18-2011
- Posts 16
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
I don't know about this picture posting stuff but I managed to get them on photo bucket
http://s1198.photobucket.com/albums/aa454/hwystar4/
Søren Mexico
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.50.93/avatar.jpg)
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
To upload one pic to a reply, place you curser where you want the pic, pick, above the reply frame, OPTIONS, pick ADD/Update, in the pop up frame pick Browse, find the pick in your comp. click open, in the frame click save, go back to compose, the pick wil be uploaded when you post your reply.
Or like this if you want more pics in the same reply.
First go to your account, upper right corner, click signed in as,
scroll down click "my files", down left you have browse and add file, on
the right add folder, if you want to create diff. folders, enter folder
name and click "add folder", open folder, now click "browse", in your
computer find the pic you want to upload, click "open". Now click "add
file", your pick will upload and show in the folder, next pic same.
to post a pic, open your new thread or reply to one, text your answer
or opening remarks, click the film strip in the menu, click "browse",
Your files will show, click the folder with the pick, double click
the pick, the pick will show where your curser was placed before you
clicked the film strip.
Before uploading, edit your pics down to some 640 x 480 pixels, that
will give you a faster upload and the pic will fit to a forum page.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Rich
- Posts 1,089
hwystar:
Sorry, that is not the same as the multi-part pieces I encountered in the RX 2. I won't be able to help.
Good luck!
Zonker92
- Joined on 09-07-2011
- Posts 3
My first post here:
I have an RX that's I'm fixing, and it's missing both of the two outer tabs (see photo below) and their screws and washers. Are they the same as the one in the center, which looks like the picture from the 3404 clip above (see second photo below). Does anyone have these parts?
Thanks!
![](http://i1021.photobucket.com/albums/af333/Zonker92/IMG_1000000874Large.jpg)
![](http://i1021.photobucket.com/albums/af333/Zonker92/IMG_1000000875Large.jpg)
Søren Mexico
- Mexico city
- Posts 1,621
Screws and washer are available at a good sorted hardware store, the tabs maybe from Martin, or buy a piece of Nylamid and make it yourself.
And welcome to amazing Beoworld
Zonker92
- Posts 3
Thanks! (I see you have 999 posts. :)) The screws and washers ... I'm sure I could find something comparable at the hardware store, although I'd probably have to use a Nylock nut instead of a threaded insert.
I'm definitely up to carving a new set of pieces with my trusty Dremel tool, but I thought I'd ask around here first, mainly about the clips.
Oh, and when I reinstall the dust cover, should I follow the advice above, and attach the springs with the ends free, install the cover with the center clip, then bend the springs down to go into the slots on the cover?
hwystar
- Posts 16
Thanks to Martin I got the parts needed and it was not easy but I managed to get it back together and now enjoy my 3400 with a functional dustcover. I did let let the spring float free while focussing on the clips first. At one point I used a pair of pliers to hold the spring in position while tightening down on the outer clips.
Søren Mexico
- Mexico city
- Posts 1,621
Thank you for posting the result, a lot of times members forget this, and here is my post No. 1000
Page 1 of 1 (12 items)
